Any more spec's on your system, large hard drives may not be supported by older hardware (older than about 18-24 months).
How much RAM, what CPU and how many MHz etc...
Well in that case yeah it could be simply setup and a good optimisation would greatly improve the speed.
Loading time and anything that requires hard drive access would be reduced a fair bit by using a fast hard drive like this one but it isn't the only thing. I'm assuming you'll be using Windows 98 on a Pentium 2
alinche, if i've ever seen an incorrest statement, its yours.
It will not improve everything, ie CPU speed, it will not improve gaming frame per second performance, it will not improve video encoding performance, it will not make a noticeable difference in internet speed unless you have cable/high speed DSL.
What it will do is DRAMATICALLY improve anything that requires hard drive access. Since it will be well over 5 times faster than a comparable drive under 10 gig, it will make a very noticeable reduction to boot speed, program loading times, paging memroy to the hard disk etc. Most P2 boards will support at least UDMA3 (ATA33) and that is about the highest sustained rate of today's hard drives. Typically 30 Mb per second.
Bozz is right.
I have 2 HDD's in my system (XP1700, nForce2 Ultra, 1gb ram, etc etc)
1. IBM, 40gb, 7200rpm, ATA100, 2mb Cache, 2.5yrs old
2. WD, 120gb, 7200rpm, ATA100, 8mb Cache 0.5yrs old
The WD abbbbsolutely sh1ts all over the IBM in speed even though they are very -similar- in specs. Being a newer drive with better technology even at a very similar spec it is much quicker in everything that it does.
Everything you do in Windows involves disk access so improving the speed and quality of your hdd will be a huge improvement, although obviously not as much as a brand new system (but $140 against $1,000 is a nice upgraded and also if you upgrade later on you can just throw the 80gb WD into the new system and it will battle on).
Originally posted by NisMojo
Holy crap... 4 GB or Ram would rock ... Force install Core windows to Ram.... 3 seconds boot time hehe
Bit like the 386 and 486 days, you know, before Windows 95 :rolleyes:
But hey, they were 0.5-1 second boot times, perhaps 1.5 sec if you used Speeddrive and QEMM386 for improved performance :D
But anyway, the HD sold for $130 a couple of days after the post.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
