::Edit:: Alrighty..Last night I opened up the boost sensor and gave the circuit board a look over. No loose solder floating around and nothing loose. I did notice a bit of build up around one of the earthing/power terminals which had caused a brownish/amber gunk that had crystalised and spread across a small portion of the board. It looked to touch two parts of a circuit so gave it a gentle scrape and clean and put it all back together. I've been for three drives since then just to test it out and try and get it to fault but it still working so for now I'll assume that whatever I did fixed it. I can all but assure you I'll be back in no time at all to say it was all bull and isn't working again...I hate electronics and it hates me!
Alrighty...I'll do the intro thing another time. I've met a few of before away from here and Im sure we'll get to the pleasantrys when they're due. For now though I need a little help.
Long story short. The boost readout on my MFD works intermittently and it's p*ssing me off! I don't drop boost at all just the output.
I've checked the hose to the boost receiver unit and that's in one piece. I've checked the electronic connections to the receiver and that looks good too. I'm thinking it's the receiver but if that was the case wouldn't my PFC have a spack attack not being able to read boost?
I'm still getting used to all the 'extras' on my car compared to my rather simple v-twin, NA, carb race bike...so easy to tinker with that comparitively.
Anyhow...I was hoping to see if I could try someones receiver unit for a quick drive to see if it still faults so I can start to eliminate causes. Not sure if the GTT one is the same as the GTR though...I'm guessing they are.
I'll be on the cruise on Sunday from Scarb so if someones willing to let me spend 5 mins swapping sensors over that would be great...
otherwise...other ideas/input would be welcome :-)
Cheers
Edited by Rkay77
Ahah! Another club to join. I have had the same problem. I borrowed another map sensor unit from an R34 GTT (I think) and mine was cleaned up a bit by Imports 101 (I can ask Danny what they did - I think they sent it to a local electronics shop, who re-soldered a loose widget). It then worked fine for 6 months and has just started doing it again. I have now borrowed a unit from an R33 GTR (all exactly the same part number) and it seems to be OK again. BUT today it appeared to stop for a while on the freeway, but I was a bit busy in traffic to confirm it.
I may be going for a new unit. Busy tomorrow, so probably won't make it to Scarborough, sorry.
Cheers. :D
So Im not going crazy!! Thanks for sharing!
I thought there HAD to be someone else in the world having this issue but I couldn't find anything anywhere about it. I cleaned up the terminals of the sensor and that didn't make a difference. I'll see if I can I do a swap with someone today to see if we share the same problem.
I'm looking at grabbing the NISMO Ver2 MFD board and sensors in the near future...
Its a bit of a worry that you've had the problem return after having had it fixed...i understand with the R34gtt one as it was resoldered....not promising if the R33 has gone haywire too... what could our cars be doing to cause this?.... a common hate for now being in Perth??
Interesting - sounds like the quality control on putting these things together got a bit patchy in the later years of producing them.
I will see how I go with the borrowed one from the R33.
Cheers. :D
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
