Hey guys,
Whats a good place in Sydney to get a boot lip wing for a 33 gtst?
I have a series 2 wing on it, however am pretty keen for a change in looks and have always loved the look of those wings.
Anyone know where to get them or prices?
cheers,
Chris
https://www.sau.com.au/forums/topic/209257-so-im-after-a-new-rear-wing/
Hey guys,
cheers,
Chris
oh you ricer!!!!
We will be releasing our Carbon Fibre version very soon (RRP is $199 FRP and $299 Carbon, uses existing holes and will be the easiest to install thanks to the bolts already in the wing that line up with the existing holes) :laugh:
PSI Parts - cheers mate, if you could keep me updated that would be tops!
Carbon would be good, but theft risk not so good :D
James - hahah you can talk GTR wing boy!! lol
I had a chat with the toy shop at Newcastle, they are getting some in also but all 2nd hand. PSI Parts, yours brand new yes?
anything in the works for r32 shane?
Yes, although mainly interior at the moment. Stay tuned.
I doubt theft would be of huge concern as it's bolted pretty solid to the bootlid. Yes these are brand new. Keep in mind that the Carbon one will not need painting.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
