R32 GTS-t Standard Airbox with used HKS panel filter
Condition and Additional Info: Airbox is in fair condition, comes with used HKS panel filter (probably needs a good clean as it's been sitting around for a while). No mounting bolts included with airbox.
Pictures:
Reason For Sale: No longer needed.
Contact Details: PM or SMS or Phone: 0411 842 861
Price and Payment Conditions: $50.
Delivery & Conditions of Delivery: Pick up. Will Post at Buyer's Expense.
https://www.sau.com.au/forums/topic/209427-r32-gts-t-standard-airbox/
You could go to a fasteners (nuts and bolts) store and get some one that will fit.
Should cost no more than $5 - $10 max! (i think its only 4x small bolts you need). It wont be difficult at all - Take the car and airbox to the fasteners place and they'll find ones that fit.
Shouldn't cost any more than $15 postage (most probably less - i will have to check the weight and measure it all up though. I just guessed measurements for the postage cost calculator on Australia Post site).
Could take up to 3 business days to get there.
Let me know.
Cheers
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
