Item:Turbosmart Pro-Gate 45mm external wastegate
Age:Few years.
Condition:Good, few scratches and what not here and there. Clamps showing there age, etc.
Price:$450 shipped OBO
To Fit: (What car) Any
Contact: Email @ [email protected] or ph: 07 3424 0044 after 4PM
Comments:
Have had my car pulled down and fit a new turbo kit w/ wastegate. This is now surplus to my needs. I replaced the diaphram about a year and a half ago just before I pulled my car down for upgrades (yes, long project :D). Gate will come with new weld on flanges.
  • 3 weeks later...
