i still cant get over how fast it is now... if i had shit tyres on the back... the thing would be downright dangerous. even with really good tyres on it atm, at 4500 rpm in 4th it starts to squirm at the rear lol.
going to be fun drifting it now :D
Just to clarify, the turbo is the cropped version, rb25 is a 100K km stock motor which has had plenty of thrashing from me with it, perfect health so far, stock intake manifold stock exhaust manifold also.
Just to confirm aren't you running some sort of GCG housing on the cropped 3071R or am I mistaken. Good result nevertheless.
Nice result.
Out of interest, was it the inlet or exhaust that had the biggest effect on the curve? And what did adjusting the exhaust side do to the overall shape (seeing as i only have an adjustable exhaust wheel and retain vct)?
i forgot to reply to this. We tried Advancing the exhaust gear also, according to what revs210 said above thought we would give it a go, and it lost a lot of power everywhere, so we then set to zero, and it was the same as the stock gear (obviously) so knew we were heading in the right track, then retarded the exhaust cam by a few degrees, made power, then settled on 1 degree and it gained a bit more, then once we started advancing the intake cam thats where bigger gains started happening.
We really ran out of time, so i reckon theres more in it by retarding the exhaust cam some more, its just that it takes 10-15 mins each time to get to the exhaust cam gear, as opposed to 5 mins for the intake.
yeah mate, GCG supplied the turbo, its a cropped t3 version with a GCG cast copy of the op6 housing and its a .71 A/R bolts up to RB flanges etc. seems to work really really well!
Good to see you had a go at the advancing of the exhaust cam, at least in the interest of science we have some data to help others out with the install of a similar setup. I regret not taking more notes with the cams I have done in the past, especially as I am going to be dropping in some more to the GTR I have now.
It appears tighe use the 0.006 lift to name their cams.
708c - 254 duration 8.5mm lift
805c - 261 duration 8.8mm lift
806c - 264 duration *not 100% sure unable to find the data*
brup brup brup. :)
Whats the idle set at simon?
  • 1 month later...
I was looking at one of these, u had trouble keeping the boost below 20psi originally, did u fix the problem, was it to do with the .71 a/r?
no it was the gate, the hole was too small IMO so i bored it out, modded the flapper so it sealed better and bored out the screamer pipe (a bell mouth dump would prob have better boost control) and boost then dropped to 16 psi (its a 16 psi acuator) use the boost controller to bring it on harder and at around 17 psi and it was sweet.
i highly doubt they will run under a bar tho... the gate just wont flow enough.
240rwkw 'maybe' 250rwkw if your lucky with simply bolting a highflow on.
260rwkw with cams from the highflow.
Go the GT3071 and have the w/g ported from the word go and your looking at potentially more.
Highflow option in my opinion is just crap. 240-250rwkw is slow; if you don't think it is then give it 3 days and it will be.
For a car to consistently feel reasonably quick you really do need 280rwkw odd.
Go with simons setup you really cannot go wrong. Skimp a couple hundred and go the highflow and your looking at disappointment.
I've been for a spin in Simons and it is very impressive; to myself its not laggy; has awesome mid range and top end; and I hate lag. :)
haha thanks cubes.
Its a pretty simple fit, the 4 studs need to be changed on the manifold to allow the spacer to fit, then custom oil and water lines and a silicon bend for the outlet and inlets... all pretty straight forward stuff tho.
cubes is right about 240 rwkw being slow tho... i have driven a few 240 rwkw r33's and they just dont feel fast at all... if you havent had a high powered car before then sure it will be fast for a while.. but you get used to it.
with mine.. it still scares me :) esp on a cold cold night in the hills i cannot floor it at all at it justs gains way too much speed too soon :P
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
