Guest Peewee
Hey guys i have an R32 GTS-4 for sale
It has all the usuall trimmings like
ABS
Airconditioning
Four wheel steering (hicas)
Four wheel Drive
Power everything i.e windows,mirrors, etc etc
The car is painted in S15 blue inside and out
Plus a full 93 suede interior with R33 GTR drivers seat
Cd player 6 X 9's andfront splits
Aftermarket gear knob
Bosch 044 fuel pump
1.5l fuel swirl pot
super heavy duty daiken 5 puk brass button clutch (still very driveable)
Huge front mount intercooler with custom piping
Haltech afetrmarket ECU
Alluminium Radiator
Alluminium Oil catch can
Aftermarket coils With 10mm spark plug leads
Metal Headgasket in engine 1.2mm
3" pod air filter
Custom blow off valve
Full 3" exhaust from turbo back and high flow cat with stainless barrel muffler
Adjustable upper rear control arms (cusco)
Kings spring 2" lowered
18" wheels with brand new tyres
Nolathane castor rod bushes
Brand new timing belt and water pump
car has travelled 75 000 kms
Car is in sydney
If anyone is interested please email or pm me.
Or just call my mobile 0407010781
https://www.sau.com.au/forums/topic/20956-perfect-r32-gts-4-for-sale/
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
