Man these RB engines are strong! The story goes...
Had it tuned Sat morning. All the air/fuel ratios were right and it made good power for stock turbo and cooler - a tad under 260rwhp.
It was a beautiful day and after having a bite to eat - my arm was twisted by a certain whore expert to go for a drive so we decided to drive up to Chittering...
After a gentle cruise up the freeway and a meander up towards the pine plantation near Wanneroo raceway, we turned off toward Great Northern highway and started passing some slower cars (which just happened to be all of them:D).. After a nice run I was onto the final straight and doing some good revs in 5th when something let go and I lost power... "hmm" I thought.. "wonder whats wrong?"...
We pulled off - inspected my engine which seemed to have a slight miss, decided the plugs had finally given up and decided to continue on and pick up some new plugs on the way home.
After a nice drive out to Chittering, back via Joondalup and through to my place in West Perth, everything was running ok with the exception of a slight miss.. My baby idled itself down in the garage and the whore expert and I went to work to replace the plugs...
What I saw next nearly gave me a heart attack... Somehow numer 5 plug had lost most of the hook over the electrode.. it just seemed to have melted away... "hmm.." I thought "wonder what the others are like.."
Number 3 was the next casualty. All I can say is that it had been obliterated... the hook over the electrode was completely missing and the electrode itself looked like it had suffered some sort of explosion as it was missing down to about 10mm inside the plug...
Panic stations were manned and calls were made.. I ended up replacing the plugs and turning it over.. Everything ran ok with a slight miss at idle - nothing more.. I let it be and decided to limp it up to a garage today...
Enter the compression test this afternoon. I would definitely recommend the Ultratune in Warwick. Dave the mechanic who works there is an absolute champ..Anyway - I digress.. So we pulled out the plugs (that were quite white) and attempt to do a dry compression test and it turns out his new guage is broken. Never fear, you could actually hear the difference between the compression in the other cylinders to number 3 cylinder. Then we try a wet compression test and it seems to come up ok. So we bolt everything back together and do an emmissions test on it. This showed excess fuel/oil which would indicate a tired engine. While it was idling, there was an arcing noise coming from under the plastic cover over the coils which seemed to coincide with the missing.
All of this tells me a few things:
1. The white plugs (100kms old) tells me that it's running lean
2. The wet compression test tells me that number 3 is low and that the rings are possibly to blame
3. The arcing sound tells me that one or possibly more of the coil packs is doing something it shouldn't
So after all this I gave the car a right caining, as it desrved no less, and everything was fine. Aside from the missing at idle, everything else seems in working order...
Plan of attack:
1. Talk to the tuner and possibly run it up on the dyno again to find out why it's running lean.
2. Get an endoscope and check out the damage to number 3 cylinder.
3. If not too bad - thrash the car like normal.
I'm thinking that the low compression has always been there and I'll fix it when I get round to doing a full rebuild..
Comments? Opions? Have I reached the completely wrong conclusion? Help is needed...
Cam
PS - if you got this far - thanks for taking the time to read it!! :D
https://www.sau.com.au/forums/topic/20986-blown-plugs-and-it-still-works/
  • Replies 42
Nope.. I'm thinking that a bit of low compression in one cylinder is something I can live with for a while.. What I am worried about is why it is running lean when the fuel ratios were ok on the dyno...
Ever since I ran up more boost I've had a problem with the car misfiring. Its not all the time just now and then, pulling the plugs out and looking at them doesnt really show the car running too rich, although the dyno's AFR says different. I'm thinking my missing issue could be something simular to cams.
if you melted a spark plug end i would be checking the air fuel mix this tends to be a severe warning that you are running too lean,the next sign would be cooked rings resulting less compression and or a hole melted into the top of the piston,i have seen this happen before and it's easy to avoid.Check the fuel pump and pressure reg are still working correctly,if so ask tuner to recheck air fuel ratio are correct.Good luck and i hope this helps.
Thanks guys for the input so far..
Micko - yea - it ain't the injectors.. definitely coming from under the plastic cover.. quite loud..
GTS5000 - when i pulled the plugs today - all were white so something has leaned things out.. not sure why it would've changed from the settings on the dyno tho.. am going to get the ratios checked again asap...
It was still doing the stall thing when it tried to come down to idle.. Once the idle stabilises it seems to be ok..
oh yea - I'm not trying to blow it up, but a bit of low compression isn't a worry. What is a worry is the fact that it's running lean and the coil packs are arcing.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
