Hi,
I'm thinking about selling my GTR.
I will be leaving leaving the country for abit at the end of year, this is the main reason.
I paid $37,000 for it. R33 GTR V Spec. It is in absolutely immaculate condition through out the car. The interior looks like it is new, the car is basically spotless; it's in extremely good condition.
The car is stock standard apart from the exhaust system, pod filters and Tomei Fuel Pump.
It has new Federal tyres, probably 3000km's have been done.
While I'm still unsure if I will sell it, because it's a wonderful car...I'm not sure if I can sell it lol.
I looked around at a few different GTR's before I bought this one, none were as clean as this for an almost stock standard car.
R33 GTR is basically my favourite car, it will be very regretful if I do decide to sell.
I was wondering if you guys think I could get the price I paid for it? I've seen alot of R33 GTR's for much less than this, but I don't think they are as good as mine.
Thanks,
https://www.sau.com.au/forums/topic/209894-thinking-about-selling-my-gtr/
You would be holding out for a very long time, with which the general price will drop even more I did the same with mine ended up loosing more money by trying to find a buyer at the higher price. Sorry.
Keep it, put it in storage if you can afford it.
Good luck.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
