HEy peoples have a few bits for sale. As they are stock parts i'm sure everyone knows what they look like. They really are in fantasitc condition, have very low use and are looking for new homes.
Item: Set of 4 Stock R34 springs
Age: 38000kms
Condition: Very good condition, perfect working order
Price: $100 ono + delivery if needed
To Fit: R34 Skyline's
Contact: Via PM
Comments: Took out due to coilovers, have been in the shed for a long time looking for quick sale
Item: Stock r34 airbox with filter and snorkel
Age: 38000kms
Price: $120 ono + delivery if needed
To Fit: R34 skyline's will also fit R33 and stagea
Contact: Via PM
Comments: Took out due to pod filter, has been in the shed, looking for a quick sale.
Edited by mxtcy
giday mate if the r34 smic is avaliable could i grab it for say $140 delivered to murray bridge.. just down the free way..
let me knows cheers
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
