well my goal was always 700hp at the wheels on pump gas. probably a bit of a stretch with the T04z. Might do it with the 1.00A/R exhaust housing.
But i'd be pretty happy with anything over 600.
Going on other setup somewhere in the low 600rwhp is probably achievable but with the stroker and large a/r turbine housing you'll probably do it on less boost than what others have used. I've seen a vq30det with a t04z on meth on an engine dyno max out with 750hp with boost starting to taper off late in the rev range which pretty much indicates the turbo was maxed out.
  • Replies 58
Looks the goods m8 welldone. My setup pretty close 2 yours just dont have the stroker crank & cams a little different ive got 280 tomei in mine plus i got lucky 2 get a N1 block. Have 2 compare dyno runs when both are finished lol. You running .81 or 1.00 housing first. :teehee:
Looks the goods m8 welldone. My setup pretty close 2 yours just dont have the stroker crank & cams a little different ive got 280 tomei in mine plus i got lucky 2 get a N1 block. Have 2 compare dyno runs when both are finished lol. You running .81 or 1.00 housing first. :whistling:
yeah mate i was following your build. was keen to see how it performed on the dyno. How is it going anyway, get that shim issue sorted yet?
Going to run the 0.81 first, most important result for me at the moment is how responsive it will be.
cheers
Paul
There are a couple of RB26's getting around oz making 650 at the wheels with the T04Z. I figure a bit more torque from the extra capacity and a few more revs should see it get close to 700.
Not sure if i want to hit it that hard thou.
Be more than happy just to be banned from the plex for running a 10. hehe
cheers
Paul
Yeah the head is off engine out something wrong with valve guides apparently they found a few shavings in head from guides so its back at the head shop valves had a couple of scuffs on them they havent told me if its exhaust or intake but most prob exhaust but keep ya posted.
bugger man, there's always something ay.
i guess it will be all worth it in the end but sometimes it seems there is no end.
Ya dead right cant win was going to have it back 2 weekends ago they run it on dyno with 14psi & it made 311kw with no timing or full tune this on run in tune. Reved it 2 6500 only so it sounds kinda promising.
Edited by blitzxtr
  • 2 months later...
Just a quick update.
Intercooler piping done, custom catch can, custom over flow and header tank.
Just wiring up the last of the electronic gadgets now. Should be starting up this week. Nervous times! lol.
Thats MAD!
How does the HKS T04Z go?
Whens the boost kick in and how much you running?
I have sat in a R33 GTR with a GReddy T88 and the thing is lagy till 6000rpm and then it flys.
Also noticed you got the one piece inlet plenum... You planning for drag races?
Edited by (00)SKYLINE(00)
Dunno how the T04Z goes yet. Last time of drove my car it have R34 GTR turbo's.
Planning to run 1.8 to 2 bar boost.
Yeah the Hypertune plenum and single throttle body is becoming a favourite for drag racers. I'm planning on doing abit but nothing serious.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
