Come on people... grow a pair and come and support the drivers who are braving the 39 degree heat in their hot cars + suits + hot sun that is summer drift at mallala (stupid heat wave....)
its this sat, and its a twilight event, so even if you rock uop at 5 when it starts to cool down a bit, it goes til 9pm, for the brave the action starts from midday.
Quite a few interstaters, new local cars, and new drivers will be at the event, malking it a little more exiting to watch. If you're coming and planning on watching, the heat is bareable providing you prepare for it, lots of sunscreen, bring a mini pool to sit in, a gazebo, an eskey full of cold drinks (no booze... i know it sucks but thats the rules) and your laughing... you can even brinng a wet and wild slide, and whatever like some have in the past lol!
https://www.sau.com.au/forums/topic/210083-g1-this-sat/
  • Replies 46
yeah come on guys, dont be soft, if we can drive in this heat, you can sit and watch, awesome spot to sit is under the grandstands, still an ok view and keeps you out of the sun.
And for the soft ones, come up as simon said, around 5ish and you will still catch the best guys out there and the team drift.
Here is the event schedule for those interested.
G1 Round 1 ‘08
SCHEDULE
9.00am Gates Open
9.45am Scrutineering Opens
11.45am Driver’s Briefing
12.00pm Warm-up and Practice
1.00pm Break
1.30pm Sponsor Rides
1.50pm Practice
2.20pm Qualifying (5 x 20 minute sessions)
4.20pm Break
4.50pm Group 2 First 8 Battles (Second 16 Cars)
5.20pm Group 1 First 8 Battles (Top 16 Cars)
5.45pm Group 2 Quarter Finals
6.05pm Group 1 Quarter Finals
6.30pm Officials & Team Break
7.00pm ‘Group 3’ Drift
7.30pm Group 2 Semi Finals
8.00pm Group 1 Semi Finals
8.20pm Group 1 Battle for Third Place
8.25pm Team Drift
8.40pm Group 2 Final
8.50pm Group 1 Final
9.00pm Presentations
Entry is $20, children under 14 free.
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3714383
joel, simon drifts as well as bob jane fit tyres. lol
so very good then, considering they do everything for me with tyres :domokun:
lol kye, i am the former spin king, think matty took over on that one when he started going out :yucky:
hopefully now with the wider rims and tyres on the rear, ill be able to get that rear grip ive been lacking to nail turn 2.... will wait and see.
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3715046
considering ill be leaving for the track at 8:30, i think myself, flick and lukey (The Boat or HMAS on here, one of them lol) i think we will be by ourselves, lot of people tend to meet at the caltex along pt wakefield rd and go up from there.
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3715065
so very good then, considering they do everything for me with tyres :D
lol kye, i am the former spin king, think matty took over on that one when he started going out :P
tip for the day: i know its not easy but try and get the right line which enables you to put your front left wheel on the ripple strip, then ride it all the way around, this is the fastest line and also, due to the front lifting up, it puts more grip on the rear tyres, hence being faster :(
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3715357
What can I say I am soft :) No way Im going there on a 40 degree day (with an engine that has been sold)
But I do wish you all well...
I might be able to go down after 7pm to see the final battles and say hi.
Tip for the Day#2: Drink LOTS of water!
Tip for the Day#3: Keep an eye on your temp gauges at ALL times!
Cheers
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3715822
hey shaun, know you probly havnt had a chance but will ask anyway, any luck with those tie down straps you mentioned about at the dyno day?
Thanks for the tip simon, turn 2 has been a killer for me since i started drifting, very rarely nail it. Lets hope saturday is a different story.
https://www.sau.com.au/forums/topic/210083-g1-this-sat/#findComment-3717192
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
