Hey guy,
I have just put my thermo fan in the car but i haven’t yet hooked it up to the power. Has anyone else put one in a r32?
My poor little bnr32 seized up the clutch fan. :D
I want to know if i should just hook it up to a switch in the cabin or not?(manual turn on and off)
Regards Keith
https://www.sau.com.au/forums/topic/210153-thermo-fans/
I've got two switches hooked up on mine. One to the ignition, the other is a thermo switch (turns on when it reaches a certain temp). Each fan runs one relay.
I've got two thermo fans, 1x shrouded 14inch fan, and 1x 12inch fan unshrouded (no space due to aircon).
Wiring would be the same between any car.
https://www.sau.com.au/forums/topic/210153-thermo-fans/#findComment-3717346
I use a 14" thermo with the standard shroud, its controlled by an electronic thermo switch that reads from the standard sensor in the thermostat housing...
Ive never had over heating issues since I started using this set up, I have the switch set to 84 degrees and even on a hot day it doesnt go over 91 maximum.
The best thing about removing the engine fan is the increase in engine response, by taking off the standard fan you reduce parasitic drag on the engine by quite a lot which makes it much easier to rev.
https://www.sau.com.au/forums/topic/210153-thermo-fans/#findComment-3720084
  • 1 month later...
Have fitted plenty of these to GTRs and GTSTs. The main thing is to make sure that the radiator is a twin core one as the late version gtst had single core and don't seem to work efficiently with thermo's.
As for wiring, the best way is to use a thermo switch to control them. These can be as simple as a probe that sits underneath your radiator hose or a fan switch that is tapped into your manifold or a adaptor in your hose.
I usually go for the first as it is easiest, but have used both with good results.
Do not rely on manual switches as there will come a day when you will forget.
As for wiring it you will need either two relays or the one i use is a 70amp one that you can run both thermos from(much easier and less wiring)
Here is a brief description of how it wires in.
The thermo switch turns the relay on by giving it a earth when it reaches it preset temp and the relay then turns on both thermo fans.
Put the thermos behind the radiator in between the radiator and engine as they cause an airflow restriction when they are in front. You can use two 12" which are actually 13" in total diameter and these will fit perfectly or you can run 2 13" by overhanging them and blocking the sides in so they can only suck through the core.
Make sure you stagger them so that one thermo sits to the top and one sits to the bottom of the radiator, and also make sure they are wired and fans are spinning the right way to pull air instead of pushing air.
If you need a diagram drawn i would be happy to or i can show you how i do it as i am doing one for a customer at the moment.
https://www.sau.com.au/forums/topic/210153-thermo-fans/#findComment-3806394
Ok this might sound a bit dodge, but talked with my local auto electrician, and he's a bit of a lateral thinker (does good work) He said I should be able to use EA to BF at least thermo fans? As they all had them from then on? Or commodore ones, just need to measure up the radiator and compare the sizes. He did say commodores had larger thermo fans. Anyone know anything about using falcon or commodore ones? Or should I steer clear of them?
https://www.sau.com.au/forums/topic/210153-thermo-fans/#findComment-3816751
Member on here with Candy red 32 with 26/30 swears by the EA thermo fans, personally im looking at the flex-a-lite thermos which are a twin thermo in a single casing.
https://www.sau.com.au/forums/topic/210153-thermo-fans/#findComment-3816776
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
