spotted 2 V35 today!
1. morning @ moore st footscray around 7:50am - white v35 coupe with a set of chromies
2. evening @ hopkins st footscray turning from moore towards city around 6pm - silver v35 coupe
was driving behind a fellow OB V35 plates wer BFV*** anyone here?
I apologise for driving a little reckless....i was in a hurry to get home to use the "toilet" (dont ou just hate that)....im not a hoon. =/ anyway nice rims!
suuure mate, that's what I tell the po-po too :D:D:D
Spotted a blue Coupe on Friday at around 6pm down Denmark St in Hawthorn.
I think it was Maximus??? from this forum, I waved and he waved back!!!
'twas me indeed. Appreciated the wave!
thanks yo..... lol... no really i needed to hurry that time and get home. but yeh i dont want to think that other V35 driver thinks im a prick...
what i did wasnt that bad tho.. lol i just needed to merge instantly..i got beeped on because i decided to squeeze in, i didnt notice the hazard in front of me and made the merging decision late.. (i was to caught up looking at his car on my rear view mirror lol.) i overtook him earlier..to get home a little faster.
Hi Juan,
Monday night fitzroy street silver V35 coupe was pulling into a under ground parking area.
I was in my V35 so yeah lol you probley would have spotted me if it was you lol
The guy i remember had sunglasses on :)
siu_loong_bao what time are you usually around there?
I've spotted a couple 4 doors before aswell, not sure if i have seen yours, maybe.
Well i've spotted a Silver V35 coupe in lygon st 2 friday nights ago had a spoiler on it :(
No one has spotted me im around st kilda, lygon st, city ect :D sucks, hopefully one day lol
I've seen a few silver coupe's on Lygon street lately (I live on Lygon street, hahaha) but don't know if it is yours. Does yours stand out in any way? Wheels? Spoiler? Reverse Camera?
Today spotted a stock silver coupe with factory reverse camera and brembo brakes parked on Russell street in the city around 5pm.
Also had another silver coupe drive the opposite direction to me on Burwood Rd, Hawthorn, around 9pm tonight.
Hey well im in lygon street a lot Friday and Saturday nights and some week nights.
Well it is just standard silver with silvers spoke rims and i have mini euro plates aswell :rofl:
I've been seeing a lot of silver V35 around now lol have you spotted me down lygon street?
