Garrett Gt2860r -5, Gt2860r -7, Gt3071r Turbos
Hi guys,
recently i managed to get a good deal with a supplier in USA to get good prices with Garrett turbos. For now, i have confirmed deals for Garrett GT2860 - 5 and Garrett GT2860 - 7 turbos for RB26DETT engines.
Price for 2 X GT2860R - 5 will be AUD$2,150 delivered
Price for 2 X GT2860R - 7 will be AUD$2,150 delivered
Price for 1 X GT3071R (T3 Flange) will be AUD$1,500 delivered
Delivery time will be 6 - 12 days after payment has been cleared
Supplier Details : PSI Parts
159 Ivyhurst rd
Amherst,NY,14226
Prices for just a single turbos or turbos for other engines, please PM me and i will contact the supplier.
Duration of the group buy will be for 2 months. Ending on 15th May. After that, depending on the demand, we may organize another buy again.
Please note, all money transactions will go directly to the supplier, i am not making any extra money through this.
Interested parties please PM me for details of payment and delivery.
Items comes with 12 months Garrett warranty on manufacturing defects.
Admins and Mods, please let me know if there is any other information you require from me for this group buy to proceed according to SAU forum rules.
Thank you.
  • Replies 88
hey there
this looks awesome, as im looking at getting turbos for my gtr
so if i deposit modey now i get them in 6-12 days or do i get them in may??
do they come with any type of warranty etc??
hey there
Hey,
If you pay now, you will get them after 6 - 12 days once payment is clear.
I will check with the supplier regarding the garrett warranty.
do these come with anything else, other than just the turbos
as, im aware the HKS kits come with oil lines, gaskets etc...
but they are more pricey
Unfortunately they just come with the turbos just the same if you buy them from hi octane racing or Croydon racing.
Yes the HKS GTSS kits come with the oil lines etc.
Got a reply from the supplier.
The turbo comes with a 12 month warranty. It can be claimed through the Australian Garrett distributors or sent back to the states either way.
BlitzR33 - Sorry you have to get the gaskets yourself. However, these turbos will bolt on to the standard ones.
I am tossing up between the gt3071r and a GCG highflow. My question is as i can not find it elsewhere what is needed to bolt the gt3071r to an rb25, is it just modified oil and water lines or the whole hog meaning custom dump pipe and intake side as well.
Guest Rotary20B
I'm in the same position, was going to get a GCG high flow but now leaning this way
Guys, if i'm not wrong, the GT3071r will produced much more power than the GCG highflow. It is similiar size to the HKS 2835 but i'm not sure on that. But it is cheaper than the high flow which GCG charges $1,950.
If you want, go to the Garrett webpage and they'll show the sizes of the turbo.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
