Veilside Andrew Evolution. Hot as.
+1 to veilside rims, they look hot as
Fail. :)
Racing Hart CS. Look closer.
There's also a Racing Hart sticker on the leading edge of the bonnet.
:laugh:
Edited by R31 drift pig
