Make:
Model: R33 Skyline GTST
Milage: Genuine 64700km
Transmission: Manual
Colour: White
Complied?
RWC supplied?
Currently registered? 28/08/08
Price: $13800
Contact: Andrew 0433233596
Comments / Modifications: DTM wheels, cat back exhaust, front mount
Images:
Edited by Moer33
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
