hey everyone wen converting a gtr from 6 throttle to big single throttle im very unsure if u have to sumhow strip the 6 butterflies out of the 2nd part which attachs to the head or do u take that whole piece off all thogether cuz that main part is where water is delivered to ur engine which im very unsure wat u have to do???
https://www.sau.com.au/forums/topic/210413-converting-to-single-throttle-body/
well for one i will be running an apexi powe fc d-jetro word is they have trouble tunning them with the 6 throttle setup hence y i want a single throttle body setup and i want the apexi bcuz its the cheaper option to still be able to have a heads up display to keep a close on on knock......
and on closer inspection the throttle bodies are actually seperate from the other part of the manifold so yeh i guess that solves that issue
PFC is one of the ONLY ECU's that uses the factory knock sensor to display a readout, its the upside of MANY ECUs.
And as for the motec/tuner/whatever - obviously he isnt as good as he thinks if he is saying it cant be done :D
Yes, but the PFC doesnt do anything about it, so unless you hear knock and keep into it whilst looking at the hand controller, or watch the hand controller whilst the car is driving, its not really much good unless you have datalogit. If you are running stock cams, there is no reason to go single throttle, the d-jetro will run it fine, just hook the map sensors up exactly as the instructions say.
If you are "hearing" knock... then the tune is simply shithouse and the tuner should be replaced quick smart.
I have never "heard" knock in any of my motors in 5 years. Its reached 40-50 on some occasions due to a cell (or two) being out, but that's it.
Any more than that has been due to too much ignition advance by my own doing.
Whilst the PFC doesn't retard like a stock ECU would, a decent tune would not reach that limitation at all.
But hot weather and/or a bad batch of fuel could certainly do it
Unless it was a race car (in which case it would be tuned for the conditions of race day anyway) then i would expect my tuner to allow a safety margin for atleast the weather which should also account for a dodgy batch of fuel.
Or maybe im just expecting to much??
i am assuming that it is tuned on one ron and only used on one ron, mine is standard but i always use 98 anyway.
do bad batches of fuel get bad enough that when filling up with 98 that it can actually be as low as 91?
You don't have to be looking at the power FC controler to see if there is any knock, if the reading goes over 60 it flashes the "Engine check" light.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
