The v35 will always be a maxima with the rear doors welded shut to me...
but I like your one, the wheels set it off. I saw a v35 with eyelids to make it look like v36 headlights, and I was very tempted...
but I'm hangin out for the v36 lol
  • Replies 44
Hahaha I didnt know you were on here..
Saw ya at Hunter last night. I stopped by for a few drinks with my mate after the photos.
oh really...where was the hello?
lol
yeh man...ive loved skylines since i was like..i dunno...since i bought 1
pfft...i want a 34....
hey i heard ur a mechanic too...when i get sum money 2gether..i want sum mods..
do em for me yeh...cheap
oh and want some advice....$5000
what should i do?
5 g's will pay your tuition and get him some rims man.... DO IT!
lol...yeh i need that too
my cars only got an HKS pod, and Greddy RS bov
ohhh and i replaced my clutch with a Five puck Brassy..wouldnt of done that but my stock clutch went after too many burnouts.
I was thinkin..
1. Turbo back exhaust w/ split dump pipe
2. FMIC..whats ur suggestions..BAR & PLATE, or TUBE & FIN?
3. Boost Contoller & a nice tune!!
I'm not made out of money lol...but i do want somethin that goes good!
I've raced a couple of stock V8's and beaten them...quite happy & surprised. Any faster than that i'll prob kil myself!
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
