hey guys/girls
i got a Beltronics Vector LR that i received of a mate for free as he said it wasn’t working last time he checked. i found a power connection for it and turned it on, and as my mate said, it comes with a error.. it starts of normal and comes up with the normal start up display but after about 5-10 seconds of being on it comes up with . " ?LO1 CAL" i asked some of my friends and one said it may be a calibration error.
Does anyone know what this error is or what " ?LO1 CAL" stands for. also does anyone know whether this problem is fixable and if so an approx. price.
Thanks any help appreciated niran
https://www.sau.com.au/forums/topic/210675-radar-detector/
hey guys/girls
I found that powering it on from cold it worked fine, if it was in the sun for too long it would start giving me that error. Lucky for me it was still within it's 3 year warranty and I took it to a supplier and repairer and they actually replaced it (and with a newer model), place was called Neltronics in Subi.
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3724498
hey guys
i rang up neltronics however the number that was on yellow pages, does not work.. If i try ringing, it just says the call could not be connected. the number i dialled was (08) 9388 9950, does anyone else know of another number for this store??
Thank’s
niran
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3725306
OK.. here's the story...
"LO CAL" (or "MARKERS" or "PLL LCK") is a fault code describing some kind of error has occured during a calibration test. BELTRONICS are keeping their software to themselves to avoid Chinese manufacturers from reverse engineering their products and whacking on the software... smart hey! :)
To repair this issue we would hopefully have a replacement board here in stock... we simply open up your faulty unit... put in the refurbished board... set up the menu and bands and away you go. The faulty board is then shipped to BELTRONICS to be refurbished and reflashed with new software.
The software repair is $95.
In WA cops use:
Multanova (not multinova!!!) which is a Ka band radar signal... low output so hard to detect
Patrol cars which use a K band radar signal... strong power so easy to detect... BUT... remember not every car is equiped and if they are, they might not be turned on
Sgt Plod himself uses a hand held laser signal... very strong, very fast, very accurate, VERY NARROW so damn hard to detect unless its fired right at your detector at which point they probably have you anyway.
That concludes todays lesson kiddies... now you can all go home, except Ossie... come here for a touching!
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3726617
$95 to repair? What about warranty ;)
Need I say more!!!
Plus the fact that a Vector LR came out around 9-10 years ago with a 1 year warranty.
Pulp, what unit do you have?
https://www.sau.com.au/forums/topic/210675-radar-detector/#findComment-3727163
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
