I have spent many hours reading about HICAS this morning, and finally understand what it actually is and what it can do. I only plan on street driving, and definately wouldnt be looking at using my car seriously at the track for a few years. My thought is to keep HICAS for the time-being when my car (car to be...) R33 GTS will just be a daily driver/street car. Would you guys agree???
https://www.sau.com.au/forums/topic/210897-hicas-for-street-use-only/
  • Replies 47
Definently agree.
For street use, and even some 'spirited' driving through some nice twisty corners, the HICAS is actually quite good. It allows the car to remain slightly better balanced through the corners. The problems occur as soon as the rear end has let go (i.e. for drifting, etc), when it leaves you with a kinda 'sloppy' feeling.
The first time you feel the HICAS kick in at high speeds (it only kicks in after about 70km/h iirc) it can feel quite unnerving... almost like understeer but not at the same time! Once you're used to it, it's okay. For "grip racing", its really quite good... but for anything where you want to maintain control over the rear end without the computer trying to "help" you, it's gotta go.
also removing hicas will make your car feel heavier when parking etc...
with 18" rims, 320mm steering wheel and hicas removed mine is like an anvil... but you get used to it pretty quick...
Really? It really shouldn't make any difference whatsoever. The HICAS is designed to only kick in at higher speeds (i.e. 70km/h+ iirc), and doesn't move under that (unless you're parking at some serious speeds! :thumbsup:)
The 4WS system on the Honda's is designed as a parking aide, as it actually works in the direct oppposite way to that of a 'line. Ours turns the rear wheels THE SAME WAY as the front wheels... the hondas turn the opposite (tighter turning circle). With ours the car kinda 'side-steps' across the road slightly rather than having to turn and lean the car over.
Edited by Samon
Can you explain why my car steered like a forklift when going around a roundabout when hicas was still fitted and working. And no i wasn't going anywhere over 30ks round the roundabout.
Really? It really shouldn't make any difference whatsoever. The HICAS is designed to only kick in at higher speeds (i.e. 70km/h+ iirc), and doesn't move under that (unless you're parking at some serious speeds! :P )
Pretty sure they turn the opposite way to the fronts to go the same direction as they are in the other end of the car. If they turned the same way it would make the car very scary to drive, by making it slide more. The tyres would be on a greater angle away from the direction of travel. As the car goes around the corner they turn the opposite way to make the tyres point in the direction the back end wants to slide in, therefore keeping more traction. I hope my explenation is understandable, it makes sense in my head.....
It does different things depending on the speed you're traveling...
As you can see from that diagram (from Nissan USA)...
Low speeds: HICAS does nothing... disabled
Medium speeds: rears turn the opposite way to the fronts at first (i.e. tighter turning angle), then once the HICAS computer detects that the car is responding to the turning, the rears turn back the opposite way, slightly reducing the turning circle but improving stability (i.e. theoretically less body-roll because it is kinda 'crab-walking' across the road rather than rotating around a center axis).
High speeds: rears turn the same direction as the fronts, like the second stage of the medium speed above.
I'm not sure of the official values for low, medium or high speeds though.
why the hell does it make the car heavier at low speeds then?
Hmmm... I dunno! It may depend on what they class as "low speed" and what you class as "low speed". i.e. if it's actually classified as "medium speed" then yeah, without it it's gonna feel a lot heavier... I'd love to throw my car up on a hoist and play around with the steering at different 'speeds' to see what happens...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
