  DiRTgarage said:
We were going to race the drag car but the deal on the supply of brakes we made with you was not fufilled.
Yeh, oops, so much for selling them. They are still sitting here :P
  AD4M said:
2nd fastest :)
LOL, if we are talking drag racing my car wouldnt even be the quickest silver R32 GTSt with Feb 92 build plate running a TD06 on 17" weds :banana: But on a circuit it might be, maybe....if you dont look too hard :)
Team NSW needs to lift their games. We lost the Super 14s, the second State of Origin , well :banana: We are due for a sporting win.
I still say when drunk i have great QC control of stale muffins at the 711 accross the road from Sydney City RSL :)
  • Replies 1.9k
Thats alright Troy...you may have saved me looking silly in such esteemed company.
We can have a drink and a laugh instead
  Roy said:
You can use them if you want to buy replacement 340mm rotors, they are cactus. The 324mm gear is fine but wont wont be much help to you or any decent powered GTR:(
Dirtgarage anyone can go in a straight line.
Hey Jason I could drive your car if you want or Roy but I think he is taken??
  STRETCH said:
i want the garage next to them. then we can charge for seats to watch. this should be fun.
We can certainly turn it on in the pits....at one event we even stripped and rebuilt the gearbox between qualifying rounds...much to the amazement of our knuckledragging opponents (V8 brigade). Who are you anyway? (not being rude)
Yes John, anyone can go in a straight line while sober...
Edited by DiRTgarage
stretch is your worst nightmare. he's called stretch cause his arms are 6ft long like the rubber man. he has been known to pull alongside you on the straight and use his super long freak arms to reach into your cockpit and turn your engine off or give you a purple nurple (very painful at 200km/h). it just depends on what kind of mood he's in as to which punishment you get. look out I say.
  phunky_monkey said:
Hey Troy, what are the replacement rotors worth for the 340mm's?
Too much, better off grabbing some CSC 343mm compete with hats and startign again with a local supply of rotors
Ok, something that hasnt been touched on how many blokes are going to bin it trying to be the STAR in a reasonably priced car? Tryign to prove they can go quicker with less :D I know i am top shelf Blue Label stuff when it comes to trying to hard and crashing and burning
  N1GTR said:
Ill go you halves
pi55 off steve...your bad luck at Oran...come near our pit and ill Voodoo doll you with a 10" flat blade screwdriver.
OK Roy...yes we have a Superfast driver...but our car is full weight (death metal will be blaring out of the on board stezza) factory brakes, laggy, and me twirling the spanners. Im sure no one is handicapped that badly.
lol, im going to set up a fold out seat and an esky full of beers in your garage then
  STRETCH said:
Richard stop giving all my secrets away.
i was going to pull aside john and do that , now ill have to think something else .
sorry mate... :P
wait a minute! by crikey I've got it. pull up to him under brakes then hit his 'push to pass' button mid-corner. effectively making it a 'push to spin off' button instead. Ross Brawn has nothing on my strategy wise...
an esky full of free beer and somewhere for me to sit while drinking it will be nice thanks Steve.
  giant said:
John didnt you just watch jacobson's drag run!! didnt look like a straight line to me
Yep I did and that was squirming the full track and a handful, and obviously quick. Got bumper bars if goes all wrong though. Still nothing compared to looking at the Tasman sea at Phillip Island 7,500 rpm in 5th and no parachute.
Edited by Boosted Zed
Your in a boat...what does it matter?
    • Hi guys, thanks for the replies.  I will have to wait till summer to test properly, but it short cycles both when heating and cooling. I’ve ordered a new internal temp sensor that sits under the vent in the steering wheel also, GTSBOY, I have an Apexi FC ecu, I’m assuming I won’t be able to diagnose or would it still work? Could the ecu be causing the problem??   the pressure switch is quite cheap I will get a new one and try it out, hopefully it doesn’t require purging the refrigerant again?
    • Do you know what size restrictor? Just flushed it with the Prestone flush & then water numerous times until the water ran clear, still looks rusted & will no doubt cause trouble later.
    • you can enter your VIN (the original, japanese one) here to find the correct part#: https://www.amayama.com/en/genuine-catalogs/nissan however, after all this time it is more likely to be a wiring issue than the sender
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
