Hey that Motokhana sounds like fun... I don't think that I can afford the entry fee however I will hopefully be cool to go down for a look... anyone else interested?? I wouldn't mind entering the one in Gracemere if it was a bit cheaper... it would be a good blast...
  • Replies 745
Hey and there was definatly a Skyline at the Drags with NOS... however a very good source also said that it wasn't all it should have been... maybe a bit more tuning or something required... but someone should definatly keep their ears to the ground on that one because it could be something to look out for...
Oh... and Jay I openly admit that I might be a tiny bit out of practice with my Wet Dorift action...... we only see rain once a century up here... new turbo, injectors and a health spot of 9 Pound boost as compared to 6 pound meant that the Silvia was just a tiny bit more sideways in the rain than normal... BUT IT WAS FUN!!!
Jay could you be talked into running the Cefiro at a Motokhana... I mean dorift event... no i'm sure it is called a bitchumen Motokhana... and it would be pretty fun to see the cefiro bagging in up...
Actually we should get Dev and Rick and Willo in on the action... it would be fun to have three GTR's at the motorkhana... It would make it interesting to see how they went compared to the lighter and more nimble 2WD's.... hmmm I think it should be done...
hey shauno... there is no great trick to getting your flywheel off... although I highly recommend that you have a mate on hand so that he can help hold the Flywheel in place... Just make sure you are pulling the socket at a neat 90 deg angle to the flywheel... the only time that the socket will jump off and reck the bolt is when you are pulling at the wrong angle... believe us... us spankers know about pulling at the wrong angle and how much it can HURT!... but it is definatly easier with two people on the job so you don't have to worry about holding the flywheel...
That is true Jay... but then neither do most of us... I was impressed with Zebal in that VL commodore... he had that thing pretty sideways... talk about Aussie drift... impressive.... and we have hurt that young VR driver bad... I don't think he knew what a handbrake was.... now he won't stop yanking on it to get a bit of 180 deg action happening... hey I guess there is no easier way to turn around in a hurry... But they were really giving it their all out there!!
Yeah it is definatly a sweet sight as that young aussie battler hangs the arse of his Commodore out, and in desperatation grabs his blinkers as he magically comes smoking out of the corner in a blaze of tyre smoke and a small dab of fear... it is almost music to my ears... such a sweet sight... I remember when I did my first drift...........................................................................
Hey you have to talk to Willo about upgrading that Internet Site... it is about time we got some more info for him to put up... actually when we catch up tonight we will through some ideas around...
Are you going to get willo to come for a Lap or what... Cefy with new wheels... a couple of GTR's what more could the lap scene in Rocky need...
Actually to all that didn't see it... check it out on www.garagespank.tk under members... when it had 18" 5 spokes on it... It looked Jap Racer... very very cool... but now he has big shinies... and it looks pimping... very very cool... have I mentioned that Squizz's Cefy looks very very cool!!
actually other than Nismo and Jishwa every one of us Spankers has over 17" wheels... most of them being 18".... that is very very cool... very cool...
Hey Jay I just have one question about your info on the members site... what exactly is R24 Bayside Blue... is that any different to R34 Bayside blue... it just I'm sure it's a cool colour... is it anything like a Maxima blue... you know... the colour you get from DC motors favourite Family car??
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
