  • Replies 163
Posted Images
How was the s/s at EC yesterday?
Was fantastic Chris..wish you where there!!
First time on E/C and first session was scary as..but once I got used to it was soooooo much fun..The best I did was a 2.09 and only got 2 sessions in cause had some problems..So much to improve on
Brad and Stephen did really well too..
yeah Stephen did a 2.02!!
thats as quick as my old V8!!!
man I wish I went :thumbsup:
bloody blown turbo's
Yeah I know I was telling stephen I wanted to see a 2.01 :D He did so well!!
Aww it's a shame ..so wont be ready for texi??
Hi,
Oran Park has the following days available in May for Private Practice.
2nd South Circuit (Medical in attendance)
2nd May North Circuit for Drifters
7th Grand Prix Circuit
17th South Circuit
18th South Circuit
On these days you must have at least a level 2 Speed Licence
Practice starts at 9.30 till 4.30pm
Cost is $130 per Driver
Note
On these days when there is no Medical maximum cars on track at a time is 4 cars
Therefore depending on numbers attending there will be sessions.
Regards
OP south Super Sprint yesterday was excellent :D
My best was a 53:39 :) Massive improvement and cant wait to beat that next time
Well done Jay was the best fun going out with you, loved the last corner when coming on to the straight!! :) Now need to find those pics!
who knows...maybe next week car is back?
but wont be doing a s/s for a while asJune 8th got a wedding...yes...on a sunday.....and then july 6th is the day after superlap...
maybe august now :)
maybe august now :)
You sound as busy as me :) will you be doing some open days to get used to new turbo?
Will be coming out to check out superlap for sure..
August it is then :D
you heading back out this weekend Duncan??
Ive got a bit of suspension work to do, and were probably going to have few of the combined touring falcons out there as well.
Oran was good on the weekend. Kept the GTR in on piece and was happy with the times considering the lack of power.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
