  • Replies 54
As I said to you when you were sending me "Blow by Blow" updates.... that's baller as f**k mate.
I hope to break 250 with mine, let alone 291 LOL....
We need to hook that boy up some sus and brakes on that thing now :D:)
Edited by R31 drift pig
Very impressed with the numbers however at the last minute we suspect the exhaust cam is a tooth out as with the stock cams the power came on alot earlier....Will keep you posted with more information
cubes, only specs on the cams i know is 264 duration and .64 something. thats all i can remember offhand..cost a bucket!
here are some pics!
Be interesting to see the results. Im betting the std cams will get it on power sooner, and probably make the same power anyway. Rb20s have pretty big cams std
ok dave here is just the sound track no picture 420kb
>>Michael 297kw Soundtrack<<
EDIT
for those that may want it on there Nokie Phone or MP4 compatible device i have it in a 320x240 format weights in @ 12.7mb oh and i took the soundtrack out
Yea steve, id love a copy for the nokia.
We're very pleaseed with it so far, haven't finished yet. Still some fine tuning to go. a fair bit more work smoothing out afr's and also ignition timing...but very pleased with 16psi tho...have plans for a little more boost with a little less timing just to experiment.
And
might i add, its a real animal on the road. >_<
Ryan
GREAT WORK !! Sleeper and a half !
Did you do any head work at all? Definetly still a 20 right?
yep hehe still a 20 dude, head work was really only a clean up. Valve seats and valve stem seals...but nothing performance wise.
mmmmmmmmmmm, i have the exact same turbo on an rb30 twin cam and i only make 254rwkw's @ 14psi!
hehe yea as i said, the 20 only made 250oddrwkw on 20psi before the cams...quite impressed with the way the cams turned out. Alot of money tho but the cams also eliminated a few dips higher in the power curve. We suspect was due to airflow. They disappeared straight away.
more to come in the way of earlier power delivery..
thanks for your comments guys, this was merely just a test car for us to learn how to tune. Big reps to the Microtech and the pc interface.
Ryan
Edited by Ryanrb25
Wasn't 250rwkw odd made with ~12psi once you done the cams and port matched the turbine housing + on a 35+degree day?
Once you push 15-16psi in to yours it should be up around 280rwkw.
Then the usual 18-19psi and 300rwkw which is the norm for an rb25det, rb30det with std exhaust manifold.
Swap out the std exhaust manifold and you could make 350-360rwkw without too many drama's.
But yeah.. it doesn't really sound all that angry in the vid + 16psi for 300rwkw with an xr6t turbo on an rb20 with cams does to my self sound a bee's dick high especially with a std exhaust manifold; but I try not to care. :D
It would be interesting to see how much more is in it on that dyno as the std exhaust manifold on boostworx dyno really struggles once you push 290rwkw. Increasing boost nets small power increases and tops out around 300-310rwkw absolute max. Regardless if it has cams, big turbo's or what not.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
