  • 5 weeks later...
i'd like to know also.
can the ball joints from the lower control arms be pressed out and replaced? i have R32 LCA's, and want to put the ball joints on my new R33 LCA's (the R33 ball joints are threaded)
i heard you can press the ball joints out, but i also heard you can wreck something in the process.
anyone know?
Edited by dmr
I've heard theyre non-servicable.. may be easier to retap the thread if the actual balljoint is ok.
I'm guessing you bought those ones from the guy in noble park DMR? I was gonna grab those but Abu had some in perfect condition for me :laugh:
You'll be happy with the results when you install them, I just put mine in a few days ago -
haha yes it was that guy.
the ball joints are perfect, it's just one of the studs has a fried thread.. and he's tried grinding the tip of the stud to make a thread again, but that didn't work.
i just rang up a friend mechanic and he advised not to press the joints out.
I havent done this myself so not 100% sure but have read on the forum here that if you buy genuine Nissan you have to buy the whole bottom control arm.But
from memory there is one trader here that you can buy the ball joints seperate for about $45 each plus fitting.I think from memory they
have a circlip (Been a while since I've had a close look),remove this then u can press them out good luck sorry I can't remember who the trader was.
Cheers
Is your mechanic mate fairly switched on or a bit of a retard? If you asked about smacking them out with a hammer and he said no, then fair enough, but seriously, if you cant press them out then how are you going to remove them? :P
You will need the correct sized dies and you will need a small press or a decent sized bench vice. If you don't have either then give up now. I have removed and replaced all of the ball joints on my 32gtst with MFR roll center adjusters. I then swapped to s14 front LCA's so pressed out the RCA's and pressed them into the the s14 LCA. It's not rocket science, you just need the right gear to do it.
Is your mechanic mate fairly switched on or a bit of a retard? If you asked about smacking them out with a hammer and he said no, then fair enough, but seriously, if you cant press them out then how are you going to remove them? ;)
if you had the right press for it then it wouldn't be a problem. i end up re-threading it and she fit on sweet.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
