Been looking at upgrading to a gt3037s pro, few questions... im chasing 400rwhp is this turbo cappable of getting that much power out of a 2.2litre rb20, and if so can it b fit into the car without having to change the manifold or any other major components? if you have a 400rwhp rb20 or know a nice turbo for that power lvl please feal free to add comment thanx
https://www.sau.com.au/forums/topic/211281-gt3037s-pro-low-mount/
a old freind had / has a rb24 that makes over 400 rwkws running a baby t88. its the smallest t88 they make, if that makes sense.
around 1.8 bar i think.
until it span a bearing.
totally useless to drive. nothing til 6500 7000 rpm then bang wheel spin, 9000 rpm redline, change gears.
sounds tuff ass with a screamer, but as i said totally useless as a street car.
my r33 with a auto could overtake him every time at 270kws.
i now have 320rwks so he wouldnt have a hope.
in saing that if it was for drag only, with a massive set of slicks it would be a different story.
