this is NOT one for the faint hearted!
you need:
male and female 8pin plugs (jaycar)
32 core 18-20awg cable 2m of it
8core cable - 3m
twin core shileded cable - 2m
single core cable shielded - 2 m
LOTS of heatshrink
6 hours of patience...
nets this:
starting:
original harness with the new one sitting behind it - those are CAN lines that I'm adding 2m of cable to..
new spot for the OE unit
note the black plug - 2m of extension lead there- no lead - no audio from external sources or anything else for that matter..
new 2m extension - one plug in place
better than crimps or tape (and certainly better than the hack job on G35driver!!)
OE nav done and tested in its final spot
all done! (top gear FTW!!)
anyone wanting this one done - find another person- I'm not doing another.
https://www.sau.com.au/forums/topic/211308-moving-nav-dvd-unit/
  • Replies 44
cookie,
if its the rear one you have then it does not affect it. waz car has a rear one. I simply will not repeat that exercise due to the time it took. unit is under the passenger seat. you do not have to electrically disconnect teh seat so it gets a bit easier. if you do disconnect the seat be aware that you will set the airbag light when you turn the key on.
if I get overwhelmed with requests I'll make up a plug in lead for it.
I'd be in for a harness . PM me if you have the data and want someone to manufacture them. I'd be happy to do low volumes.
This I would think would be a very worthwhile and fundamental mod.
Include a rear Aux TV lead harness as well.
What would a harness cost roughly?
I presume the harness would include din socket for the new DVD unit.
gibbo
I have a local place that can do them. plugs are the worst bit of it. thing being I have to buy a 1000 of each plug and the matching pins ( there are 5 of them )MINIMUM to make them. the main nav plugs are EXPENSIVE - so for the total harness it would be in excess of $300 to make properly. the TV AUX lead I keep on hand anyway - ready made for $60-75 depending on exchange. same rule there.
the estimate I did was a plug in lead with the two CAN plugs (both sides) 8 pin DIN plugs and the main nav plugs with 2.5m of lead between them. the nav antenna plug is irrelevant as that gets replaced in most cases with a new antenna anyway. (Iin the cars I do IT DOES GET REPLACED)
the above exercise was $60 in cable and connectors.
Hi Chris,
Awesome work, im looking at doing something similiar myself in the future when i find the patience!!
One quick question, does the car operate without the OEM Nav unit installed?? If it is unplugged does it have a hissy fit?
Cheers
Laine
it will. nothing will work screen wise but yes the car does run and drive with no lights. have driven SEVERAL cars around with no dash in them at compliance doing exactly what you are asking.
what do you have in mind?
Do you mean that once anyone do this, the airbag light will stay on FOREVER even though the ignition is turned back off, seat wire is reconnected, and turn it back on?
Cos there's someone on the other thread that's got an engine error message as he accidentally tried to start the car with airflow meter plug disconnected. now it seems he has the dreaded errror message FOREVER even though the car works fine now.
nope. if I had removed the seat ENTIRELY and turned the key on then I would have the same problem as the OP does. I didnt as I left the wiring intact and pushed the seat out of the way. have high res shots if you wish to look. only way to get rind of the codes is with the appropriate bit of sofware and a cable.
Ok fair enough. I was just trying to take the easy option and just remove the nav unit and replace it with a DVD unit and attach that to the aux input mentioned in the other thread. Pretty much the same as what you did!
Never mind, might just have to look at taking the same approach when the time comes....
What do you reckon of this? 40GB HDD, its' own CPU, functions as a dvd player as well...
http://cgi.ebay.com.au/1-DIN-In-Dash-DVD-C...1QQcmdZViewItem
I should've put the dvd player in when chris did the conversion work saves all the troubles now...
I came across the Nesa DVD-5051 as well, 1/2 DIN size so looks like slim enough to fit in e.g. glovebox or tucked in somewhere less obvious.
http://www.nesavision.com/dvd5051.html
Is this just as good as the other DVD-8000 that you told me about?
Hey now that should allow the existing unit to be set down and to the rear of where it is and the slim unit up and forward. That way no rewiring of the existing unit.Would depend on unit price as well.
Brillliant.
I get my v35 back next week so will check it out mate. Mine may well be the first v35 coupe to have tangled with 2 kangaroos (mother and joey) in the country certainly off the road for 3 months. They liked HID so much they leapt head first into the left one.
I can't wait ...
Gibbo
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
