  • Replies 58
hey bud,
can i buy the whole lot of the seat belts with brackets n bolts, both front & rear.
i live in Cairns, so if u dont mind having to post i'm happy to pay:)
cheers Daniel.
p.s can u pm me ur number
PM sent
PM sent
Pm replied
Any 5 stud wheels??
Just have 1 pair of 5 spoke 17's in silver. Can get pics if you're interested
List updated, few prices dropped :)
https://www.sau.com.au/forums/topic/211354-sold/page/3/#findComment-3774556
pm sent about that cat
Pm replied
still got RHS headlight?
Sorry mate it's sold to J'z-R33 :P
Yeah can you send me some pics please? How much you after for the pair?
Thanks.
Heres a pic:
Pm sent
hey mate
if you don't mind selling the Snorkel alone with no airbox, i would be interested :rofl:
PM when you get the chance with a price :P
At the monent just looking to sell them together, I'll let ya know if i decide to seperate
any chance you have the unleaded fuel restrictor neck?
Kent
Is this what you're after?
If so, yep. $40
https://www.sau.com.au/forums/topic/211354-sold/page/3/#findComment-3779027
Hey guys
picked up another R33 Skyline for wrecking. It's had a knock on the front left so the bonnet, left guard, headlight, etc etc are gone
Rb25det turbo engine- has 93000 k's. Has had new Gates timing belt installed @ 63,000ks..
Compression tested this engine, good results accross all cyl: 154 155 153 154 155 154psi
Complete motor, wiring loom, S2 turbo/lines Sold
5sp Manual conversion kit (5sp box, clutch, flywheel, tailshaft, pedals, clutch master/slave cyl & all lines) -$1900ono
everything ya need to convert an auto to manual!
Series 2 AFM (pink sticker) - $120
window washer bottle - $20
radiator overflow bottle - $20
Engine bay fuse box cover - $30
3" dump/front pipe combo $100 PICKUP!
3" Catco cat, 487CFM - $80
3" catback exhaust - $160
Drivers side S2 foglight/indicator Sold
Aircon compressor $120
coilpack cover $40
standard airbox + snorkel $90
Brakes/Suspension bits:
Power steering rack - $125
castor rods - $80 pair
TEIN HA front coilovers - pair $350 Sold
stock rear shocks/lowered springs - $150 pair Sold
front rotors, top condition - $70 pair
front calipers - $300 pair
rear rotors top condition
rear calipers - sold
front hubs $80 each
rear 5 stud hubs - $160 pair
front upper control arms- $60 each
rear lower control arms- $70 each
rear upper arms - $50 each side
handbrake drum assembly + cables - $220 pair
stock viscous ABS diff - $250
driveshafts/halfshafts - $80 pair
hicas rack - $30
front swaybar - $20
rear swaybar - $20
rear cradle - $50
Exterior bits:
rear Skyline fascia, white - $40
bootlid, no spoiler, shaved boot lock - $150
fuel flap lid $15
Interior bits:
Instrument cluster - manual with 93000ks - $100 Sold pending payment
S2 airbag steering wheel, $225 ono
dash gear surround w/ leather boot and cig lighter - $50 Sold pending payment
climate control unit, as new condition $60
larger dash surround w/ clock, hazards etc - $100
Series 1 door trims - $60 each side
drivers side window motor -
handbrake boot, immaculate - $25
stereo mounting brackets - $25 pair
series 2 front seats in top nick - $200 pair
series 2 rear seats $80
glovebox - $30
floor carpet $80
centre console lid, perfect nick $40
seatbelts & buckles + bolts full set - $100ono
steering wheel surround plastics - $30
both headlight & indicator stalks - $40
parcel shelf - $40
complete boot interior (except piece that covers battery), good condition - $80
electric aerial $50
rear wiper motor - $50
PM for anything not listed!
Pickup welcome, or I can post anything as long as its not too big for auspost
Located in Sydney, near rockdale
cheers :(
hey im interested in your stearing column plastics and was also wondering if you the drivers side window switches at all
thanks Matt
https://www.sau.com.au/forums/topic/211354-sold/page/3/#findComment-3789533
How low are you willing to go on the price for the front r33 calibers?
Pm sent
thanks Matt
Pm sent!
https://www.sau.com.au/forums/topic/211354-sold/page/3/#findComment-3796714
Sorry to anyone who tried to msg me last night but couldnt, my pm box was full
hey mate do you have the passenger side door trim? also the latch goes into lock the door (attached to outer door) also ur location?
Cheers.
Yep, PM sent
How much for the relays from the interior fuse box, the 45amp fuse from the boot for the blower motor and the fan/blower motor. Thanks
Pm sent!
just wondering if you still have he front and rear seats, and if possible all the door and rear side trims also.
you wouldnt have the standard computer would you?
Yep i still have the seats and door/side trims, sorry no ECU though. PM sent
https://www.sau.com.au/forums/topic/211354-sold/page/3/#findComment-3799793
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
