Item: R33 skyline
Website: here
Item Condition: used
Reason for Selling: not needed
Price and Payment Conditions: below
Extra Info: if theres any thing needed that isnt listed juz ask may have cheerz
Pictures: soon
Contact Details: pm here
HEAD LIGHTS $400 FOR THE PAIR
TAIL LIGTS $150 FOR THE PAIR
BONNET IN RED WITH MEGENTA FLEC $180
STEERING RACK WITH RESIVARE AND LINES $150
FRONT AND REAR KYB SHOCKS WITH PEDDERS SPINGS LIKE NEW $400
BRAKE BOOSTER AND RESIVARE $100
REAR BRAKE CALLIPORS,ROTORS $180
REAR HUB SET UP $180 PAIR
REAR SEAT $50
SIDE MIRRORZ $60 PAIR DRIVERS MISIN GLASS
2x RADIATORS WITH SROUDS $110 EACH
POWER WINDOW MOTORS $50 EACH
FRONT LEFT BLINKER SERIES 1 $50
LOADS OF PARTS INCLUDEING INTERIOR PARTS,OTHER SUSPENTION PARTS,ALL SORTS ALL PRICE ONO
https://www.sau.com.au/forums/topic/211592-r33-parts/
pix here
http://www.boostcruising.com/forums/index....entry1282082915
also decided to sell my custom hood lining and other interior bits as the red doesnt suit my green 33
$650 for hood linging and bitz cheers
https://www.sau.com.au/forums/topic/211592-r33-parts/#findComment-3749427
sorry kretch engine bay loom went with motor and box sorry
hood lining still for sale cumz wid inner roof mould things front and rear and sun viserz all cover in the sam red velour was ova $1200 to be dun make an offer
https://www.sau.com.au/forums/topic/211592-r33-parts/#findComment-3780650
  • 1 month later...
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
