Me,
i decided to get my shit together since its warm again, and get the stag back together
i wanna take it to the track for drifting at least 4 or 5 times this year.
BUT we will see what happens.
today:
Finished installing SAFC2
settings aer 4 in 4 out (i asked this question last year and noone knew)
Flushed the radiator, reset idle
put the back tire back on
installed bride Brix2 and rail
i ordered some Dmax rear TOe arms since i tweaked the rear subframe on a speedbump and i need it to get it aligned
Will be putting on 9j -17 front 10j -7 rear (hopefully)
I will alsp be transplanting my airbag setup from my nissan cedric to the stagea
its a kinda proprietary airbag that replaces the spring etc etc etc
anyways, stay tuned, pics and stuffs will follows
https://www.sau.com.au/forums/topic/211638-guess-whos-back/
i can
but its kinda expensive.
but i can.
I must have a rear spoiler, wing, or whatever. I am the only poor DB that does not have a rear spoiler.
HELP> EFFING HELP.,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,please
https://www.sau.com.au/forums/topic/211638-guess-whos-back/#findComment-3745165
hugh im contemplating getting rid of mine but wont know til i see the car up close... dont know if i like the idea of a spoiler on a wagon. But we'll see.
dont touch your autech kit!!!!!!:ermm: hands down best kit for the sexwagons imo :ermm:
https://www.sau.com.au/forums/topic/211638-guess-whos-back/#findComment-3746931
haha i like the Dayz rear wing over the big bulky one but im sorry... the rest of the autech kit pwns the DAYZ. Sits lower, more agressive...
We gotta get a photo shoot on carter! What year and colour is yours?
https://www.sau.com.au/forums/topic/211638-guess-whos-back/#findComment-3747337
I don't have one either, Hugh.
I'm guessing they're a massive help for keeping dirt and rain off the rear window, so Bobbeh I suggest you keep it on. My rear screen is always dirty after the rain, and it's a PITA.
https://www.sau.com.au/forums/topic/211638-guess-whos-back/#findComment-3747741
I bought an Autech wing years ago when i first bought my car, it was one of the first mods I did. Very awesome wing, makes the car stick out a lot more, and makes it easy to find in the car park.
I've got the DOLPHIN wing, which l'd say would stick out just as far (if not more) as the Autech, and def agree, makes finding the car in a carpark very easy!!
https://www.sau.com.au/forums/topic/211638-guess-whos-back/#findComment-3749503
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
