Hi everyone.
Just bought a 2000 GTR R34 vspec 2 from japan and i was wondering if the tv sat nav unit can be converted to australian specs?
Any thoughts would be much appreciated.
Thanks in advance.
Nick.
bump
  • 4 weeks later...
ok putting it more bluntly - the nav unit alone is $1300 add cables and modding and time and you have little change from $1600..
I work on these things DAILY and that price tends to back people right off unless they are serious.
Edited by Chris Rogers
Hrm yeah thats someone I would use.
"Yeah I can fix it, but im not going to tell you a price, how much money you got though?"
Don't go Flaming people when you havent been on these forums for long. Have a look at when Chris joined the forums and the number of posts he's made. He's helped numerous people out on these forums and written DIY's on various things. Also as he mentioned he does this stuff for a living.
Have a little respect for others on here.
Wasn't flaming the guy mum, just saying from a customers point of view I dunno about anyone else but saying "what do you want to spend on fixing it" rather than just giving a price is more going to put me off getting it done.
I havn't been on the forums long either (been lurking for a while though) and can see that Chris has got answering questions down to a fine art.
Basically, if he was to write out information heavy posts in response to every single question that he does reply to (often posts are directed AT him) then his hands would have worn off from typing, long long ago.
Now, without further hijacking.
- Chris, would you recommend simply getting a standalone unit? I assume they would be much cheaper and do the exact same thing.
Mate, just have a read around the car audio forums - chris is one of the most respected guys here in terms of his helpfulness and knowledge of skyline audio installations. He's not trying to make a buck here.
up to you really. most people opt for the stick on glass things as a easy way out . they do tend to get lost and do strange things. the fixed items are a lot more robust so they give very little probelm. I have been using the GARMIN GVN52 in most of mine and have zero probelm with the unit.
for the 34GTR thats the best route. for a 34 with OE screen (howie this is directed at you.) its your choice. I can have a DVD playing on that screen in minutes with the audio routed back out of the main radio OR with a bit of fiddling nav done in a similar fashion.
still waiting to get my hands on a R35. have been asked to look at one in sydney but thats something I'm gong to wait on due to lack of time.
So are you saying that the screen out of the 34 gtt can be made to play dvds if you had a head unit that can play dvds.
Any help would be great.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
