Hi Guys, My Name is Yury and I own a 1990 Skyline GTR. I'm actually from Canada but I need all the help I can get diagnosing a problem....
Here's my problem....I seem to be getting oil in my coolant. I have flushed the system numerous times but the oil just seems to keep finding its way back in. When I check the dipstick, the oil level doesn't drop very much, in fact very little. I know one possibility could be the head gasket, but I was wondering if anyone could suggest somethign else. The oil is clean of coolant. Also, my oil seems to turn black fairly quickly, I was wondering if that is normal or not. I am using royal purple 5W40. Any suggestions would be greatly appreciated.
Thanks
https://www.sau.com.au/forums/topic/211657-please-help/
Try a Air Pressure Test when you do a coolent flush...
So after topping up all the coolent in the radiator, do the test then.
The pressure metre should stay and not move.
If the pressure goes down, there might be a little leak...
Might have to get the engine seals / heads checked to see any leakage. Thats all I can think of...
https://www.sau.com.au/forums/topic/211657-please-help/#findComment-3741088
It would be the head gasket mate. I've never heard of anything else causing coolant and oil to mix. Try driving up a steep hill. If your car is over heating when you get to the top it has been confirmed. Also, try and get hold of a CO2 sensor tool. That should tell you whether you have a head gasket leak or not. Otherwise take it to a mechanic. I wouldnt drive it too much though, its not too good for the engine
https://www.sau.com.au/forums/topic/211657-please-help/#findComment-3741629
A leakdown test of the cooling system and/or block/head will tell you exactly whats wrong, aswell as many other things
If your missing water then its being sucked into the engine or forced out through the o/flow. Look for white milky residue under your oil filler cap, or excess moisture from the tailpipe on initial startup, bubbles in the coolant etc.
The alloy head can crack pretty easily also
https://www.sau.com.au/forums/topic/211657-please-help/#findComment-3743924
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
