Massive Clear out of parts in my garage..
Can organise immediate pickup.
Located at West Ryde, NSW
Contact 0413005673
Item: Complete RB20DET Motor w/ Loom + ECU
Condition: Very Good
Price: $1000 Pickup $$900
To Fit: (What car) Any
Comments:
Complete, Rb20det motor with complete wiring and ecu.
Motor is stock standard, Turbo is excellent condition.
No alternator or Power Steering.
Item: Apexi Rev/Speed Metre RSM-GP w/ G sensor
Price: $200 $150
Comments: Very Good Condition, Can do Install for Free.Comes with Rare G-Sensor.
Item: Autometer White Face Volts Guage
Condition: Excellent
Price: $50
Comments: Slight Bend on outer rim, Comes with black Cup.
Item: Starcorp Racing Impuls
Item Condition: Average
Price: $800
Comments: Rims have gutter rash (easy Repair at wheel shop) & a slight bend in one of the rims, again an easy fix. Rims have tyres which are driveable but suit new tyres..
Contact Details: Alex 0413005673
Item: N1 Spec Headlights
Price: $200
Comments: Good Condition.. Comes with h4 globes
Item: 2x Green Label RB20DET AFM's
Price: $100 ea. $50 ea.
Comments: Both in good condition, One's mesh is a little pushed in. the other is perfect.
Both are 5 pins.
Item: 25 Fard Power Acoustic Capacitor
Price: $400 $250
Comments: Used once, Brand New Condition.. Animal of a capacitor.
Edited by Nismo_Rico
  • 3 weeks later...
hey mate where u located? hope its in sydney somewhere so i can check the gear out myself ...really interetsd in th RSM:)
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
