If there is anyone here who sells Kenwood gear and can ship stuff off for repairs, I could really use your help. I have a KVT-747DVD player in the car, and have spent 2 days trying to figure out if it is anything wrong with what I have done... So far no, every wire works, there is power to everything, all wires are how they should be... The screen comes up saying "Disconnected cable found. Please confirm a connection line." I'm assuming this means there is a break in the system somewhere, which is something I simply can not find in my wiring... The head-deck itself works fine, with all motor functions doing as they should, it is the hideaway box that worries me, I have no real way of testing if that is working, and have come to the conclusion that it is that box that is malfunctioning... With a slight chance of it being the large black cable that connects and communicates with the head-deck and hideaway unit... again, no real way to test...
I'm fairly certain I bought an extended warranty on this item, but there may be problems with that, being that it was bought from JB and they no longer sell car audio gear... and that I can not currently locate my receipts folder... and that I have moved twice... A search is underway, but how fruitful it will turn out to be is a mystery :(
I'm pretty certain that the hideaway box needs to be replaced or fixed, and I am willing to pay for whatever service costs it may have as if it were out of warranty...
So if anyone is in a position to help, let me know... til then, I will continue to look for the receipt and practice doing this :blink:
Thanks :D
https://www.sau.com.au/forums/topic/211714-professionals/
not me - I sell blau. track down the JB that you bought it from as tey keep a database of what was sold.
as for the main black box - could well be a dry joint. the older stackers were notorious for this.
stick with the warranty side of things - saves you the grief.
https://www.sau.com.au/forums/topic/211714-professionals/#findComment-3741932
That is my first plan, if I can find the receipt (which I'm sure I will) and it is still under warranty, then no doubt I will go through them... but incase I can't, or it takes too long, then I will go through other means...
Thanks anyway chris, I think I remember FHRX saying he had a deal with Kenwood... spose I will wait and see :thumbsup:
https://www.sau.com.au/forums/topic/211714-professionals/#findComment-3742332
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
