Hey everyone.
I was driving my rb20det r32 when it was raining today with the aircon on and my car started making a hising noise then the engine turned off.
I pulled over and turned the aircon off then started the car and it ran normally. I drove for a while then turned the aircon on and it started making the hising noise again and threatened to turn off.
What could be the problem? Im sure its only related to the air-conditioning because it boosts, sounds and idles normal.
Thanks in advance.
If its doing it only when your AC is on, i would think its AC related.
Check the belt for the compressor isn't frayed or worn. If the compressor is on the way out, it will put unnecessary drag on the motor; the idle valve isn't enough to stop the motor from dieing?
Edited by GeeTR
Check the belt for the compressor isn't frayed or worn. Compressor is on the way out and is put unnecessary drag on the motor; the idle valve isn't enough to stop the motor from dieing?
Yeh, the motor still dies. What do i check for in the airflow meter? what could be wrong?
did you convert your ac system to r134a?
the different gas makes the compressor work harder causing it to steal a lot of power from the engine.
When i turn on my ac when driving, i have to neutral + rev it a bit so it doesnt stall as i come to a stop. After doind that once, the revs stay up around the 700rpm. Just the first time i need to give it a bit of help.
anyone know why? would it relate to the ecu learning to keep the rev's up at the next stops etc?
Sweet, nice work.
So is the AC comp seized? hard to rotate?
yes its seized, needs replacing. i found a compressor on the sau for $50, do u think its worth buying it if i dont know wether it works? I thought they were worth above 250??
thanks
Edited by CandyBoy
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
