Hi, I have been recommended by my workshop to go for a GT25 440HP turbo to achieve the horsepower I am chasing (around 320rwHP) and the 'seat of the pants' torque I am chasing.
I am not so much after a dyno comp winner, but something that comes online not too late (a litte lag is cool, like 4000-4500 for full boost) and really punches hard as I hate the stock turbo - my old WRX with a VF22 pushed MUCH harder.
Anyone used one of the GT25's (internally wastegated model) on an R33? Any comments?
I originally was thinking the GT30 with a TO4B housing, but my mechanic has done several R33s with this setup recently and is getting 320rwHP with 13PSI with stock computer (pretty awesome in my opinion!) and its not laggy.
Ta
Conrad
https://www.sau.com.au/forums/topic/21181-gt25-440hp-on-a-r33gtst/
hey
i am currently about to put the same turbo on my RB20 and around 320rwhp was what i am chasing also. I know a guy with one of these turbos on a CA18 that hits 1bar @ 4200rpm. I was hoping on an RB20 it would hit 1bar by 3900-4000rpm and I would expect it would hit 1bar on a rb25 by 3700rpm (this sound right?).
Anyone else put one of these turbos on a RB20/25?
Thanx
Evan
I went for a drive in a 180 with an RB25 and GT30... very impressive and suprisingly good throttle response. There was nowhere near enough lag to make me think about going smaller if it was my car, but thats just my opinion and i can put up with a bit of lag for good hp :)
Guest INASNT
Originally posted by R33GTS25T
hks gt2530 full boost @ 3800 rpm pulls right through the gears good till 250rwkw
hks gt2835 bit bigger comes on a bit later good till 300rwkw i think...
u think wrong, the 2530 is only slightly bigger than the stock turbo and will give u about 225rwkw, and no way will a 2535 give u 300rwkw.
Guest INASNT
u think wrong, the 2530 is only slightly biiger than the stock turbo, and no way will a 2535 give u 300rwkw.
Originally posted by MFX_R33
If you are going to go to the expense of upgrading your turbo, you may as well make it worth while, and go for the GT30. After driving the GT25 for a couple of weeks you will be, searching for more and kicking yourself that you didn't go for the bigger unit.
Jeff.
Suppose it depends alot on what people are after and what they use the vehicle for?
Guest MFX_R33
Basically, there is not a huge power difference from standard to the GT25. My thought is, if you are not content with the power from the standard turbo, then you wont be content for long with the GT25.
If you are only after a few more kw, then you have to ask yourself if it is worth it, or should I just be happy getting the most out fo the standard turbo (maybe just play with cam's, etc).
Jeff.
Hmm thanks for the advice guys - will consider the GT30.
But to be honest, 320rwHP+ ( 238Kw) is pretty serious power and I understand that 260rwKw is close to the limits of a stock bottom end on an RB25 so I am not sure if the GT30 is going to give me much more expect for more lag and potentially a broken motor when I run it up to 260+rwKw..
320rwHP at 13PSI seems awesome to me - thats serious power and not insane boost, so engine longevity shouldnt be too bad. My concern with the GT30 would be it may run up to say 370rwHP, but how long would the engine stay together? This is my daily driver, I dont want it to detonate after 3 months.
Am I wrong, can the RB25 sustain more than 370rwHP safely for extended periods? If so, the GT30 is probably a better option :rofl:
Good responses guys, got me thinking about the GT30...
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
