Anyone suggest a good battery for me? I herd Pulse can be good? I am not going to replace this battery. I need dad to call sometime so I can ask him where the battery charger is in the lockup so i can take the battery out and charge it (on that note doesnt charging require a ground? how can you aquire a metal grounding when you charge from one of those Socket chargers off the wall?)
:) Was going to pickup tight arse tuesday fuel to. :yes:
Edited by Tommok
check your light in the boot goes off properly when you shut the boot
that's what drains my battery.
I shut the boot, the light goes off but if i go over a bump, the light comes on again and drains the battery when i leave it a few days.
My battery is almost dead.. then again I haven't started the car for like 3 weeks.. eep!
You can buy awesome battery charger kits that you can just plug and play. I have one for my bike.
Even switches off one the battery is full.
Go to supercheap and get one of those $30 solar panel chargers, they work awesome, and they work under flouro's (in carparks). They have a cigi plug on them but most cars the cigi lighter is disabled when the car is off so you either need to hard wire it or get a cigi female plug with allitators on it. I had battery problems when i went away for long periods, but this fixed it.
Is jumpering an option? It'll save you the waiting time. That's what I do pretty often and the cables I bought from Woolies for $11 I think they were. I also have a trickle charger and it doesn't need a ground. Steve you are right about QT, I get that too.
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
