Item: N1 RB26 Conrods
Age: ~25,000kms
Condition: Perfect
Price: $200
Contact: Paul - PM or 0402418697
Comments: Came out of a perfect N1 RB26 crate motor, motor was stripped down for more power, and rods replaced.
Item: N1 RB26 Pistons
Age: ~25,000kms
Condition: Perfect
Price: $50
Item: N1 RB26 Cams (believe they are 255/8.5mm, fair whack bigger than standard)
Age: ~25,000kms
Condition: Perfect
Price: $250
Item: N1 RB26 Cam Gears
Age: ~25,000kms
Condition: Perfect
Price: $50
Also have other items like head studs and valve springs if anyone's chasing them.
https://www.sau.com.au/forums/topic/211879-n1-rb26-engine-bits/
Pistons are Sold. They are 86mm, and I have no idea how they are different from a standard one, they just came out of an R34 N1 crate motor (believe they are strengthened with better rings?). I can source standard RB26 pistons for a similar price if anyone else is interested.
Rods and Cams are under offer.
Why do you want pics of the rods? They look like standard RB26 conrods, seen one seen them all.
These parts are listed by Nissan as "semi-forged", which is crap cause its either forged or cast. I'm guessing this is Nissans code for strengthened (shotpeened/cryo'd etc).
As said, all parts are straight out of an R34 N1 motor that was in my R33.
First come first serve, if the offer for the rods / cams falls through, the next person who PM's me about them gets them.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
