I have a 1998 R34 RB25DE and was wondering if a exhaust made for a RB25DET would work on my car.....thanx lots...and if anyone knows of an exhaust for my car send me a link...thanx
One thing I know for sure is, even though its gona fit to your NA, you will loose the volumetric vacuum/scavenging efficiency. ift is a 3inch pipe then its too big, maximum you should go is 2.5" have a look at the following posts...
Post 1
Post 2
hope this helps.....
also if i find a RB25DET Cat back and its a 99 will it work? i have a 98...i thought the only difference was the body kit...but im not sure...
2.5" or 2.75" MAX i would upgrade for exhaust..
not 3" too big!
unless you have a fully high flowing powerful NA that pushes over 150rwkw hehe
even then it'd have to be a high revving motor.
the commodore/ford V8s only run 2.5"
3" is never too big....................
in the end get what you what to put on your car and not what everyone else tells you too.
yeah...ur right...thanx man
cara you have a 3 inch on yours.. how loud is it exactly? do you feel like you loose way to much power?
but of course all that noise and no power gain... is it worth it...., no..
People here are giving advice on if a 3" is performance wise an upgrade, and the answer is no, many threads about it too...
but here if you just want a loud car ram a screwdriver through your muffler...
you're all forgetting that a power figure (although the standard) is just a mere maximal power figure.
100kw @ 4000rpm will be a better drive than 117kw @ 5000rpm. 17kw increase at 1000rpm later, i know i'd take the driveability over the peak power increase any day.
what about the other attributes, rpm? area under the curve? torque? etc. all the fact sheets for new cars provide a power figure in reference to which rpm it was measured at. 1000kw @ 20000rpm vs. 100kw @ 4000rpm plus the torque figure, you can do the maths.
if you look at all the drag racing guys - they don't care about power figures anymore. MPH at which they cross the traps is what they are interested in. there's so much discrepancy in dynos now days that they don't care if you have 200kw or 400kw.
and since i like to have the final word on things, i'd like for the rest of this thread to remain on topic. if you wish to continue this 3" kilowatt vs. response/torque debate, bring it up in one of the other threads. actually i'd rather no one did, because it'll be a repetition of what's been going back and forth already.
everyone has their preference. if you want a kilowatt number to go off and tell others go ahead, if you want response then that is also fine, if you want to back up those figures with some drag/track/circuit times even better. that way we can at least draw some relationships between power vs. track time.
cheers
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
