There somthing wrong with my R34 (GTT-no engine modification)... It began long time before I was cruising down the freeway, and then some dude went to change the line, so i just released a bit of my gas pedal then when he moved lane i tried to accelerate again but all of a sudden the engine, TCS off, slip lights came on, which apparently results in my car wont accel like it should do, the sound from my exhaust is somehow roaring and coughing.. and it does vibrate more when u tried to boot the gas pedal... But when I pulled over, and leave it for a minute or two, its completely back to normal, but u can smell like rubber burning from near the rear wheel... Keep getting this kind of problem but not too often, anyway my 5000k service is due in 2 weeks anyway, i thought so ill just wait..
Anyway I brought my car to 5000k service over in down under auto who also imported my car.. ask them bout the problem, but after the service they said nothing's wrong with ur car
Well the problem still came occasionally and will be gone if u leave it for a minute or two, went to the auto tune once and they said u gotta go to a garage who has the computer shit for R34, so it is easier to find, just plug it in and u'll know where did it go wrong...
I havent had a chance to do it though since i dont know which garage has one.. and the problem didnt pop up lately...
But around 5 days ago the problem came again when i actually wait for my order in mcd drivethru without anyhing to do with the gas pedal or clutch and another one came yesterday when i waited my friend with an engine on like exactly happened in mcd drivethru?
So has anyone overcome this problem or have any idea about what it is? Help me guys!!?
Thanks alot for reading it anyway...
https://www.sau.com.au/forums/topic/211943-r34-problem/
i'll tell ya what...
stop driving the car, next place you should take your ride is to a workshop that likes working with Sky's...
if there's no $ just save up dude, i have no idea what's wrong with your car but i have never heard of that happening to anyone's car
don't want it to get worse and worse and then cruising on the freeway in the middle lane your car just starts spinning and you end up in hospital, be careful dude that's my2c
Andrew
https://www.sau.com.au/forums/topic/211943-r34-problem/#findComment-3744938
Repost this in Forced Induction section, you'll get your answers quicker.
To me, it sounds like somethings cause the ecu to go limp mode, but find a workshop that is familiar with 34s & can get consult on it... but the problem may be caused by sporadic issues (eg. afm wires coming loose momentarily)
Ring around a few workshops and see if any of them recognize the 34s symptoms.
https://www.sau.com.au/forums/topic/211943-r34-problem/#findComment-3745055
this is not that uncommon , not common but I have seen it before on a few r34s.
i think it is a problem with one of the sensors , probably the TPS
but as its pretty intermittent it can be hard to diagnose when its not happening , usually theres no stored error so consult doesn't help much when its fine
is it a triptronic ? if it is i would get it checked out because possible tps issues can cause gearbox problems
Edited by 32vspecII
https://www.sau.com.au/forums/topic/211943-r34-problem/#findComment-3745753
i'd check with AUTOWORX as above =)
they are only up the road from DUA i originally got ma car from DUA but had a few problems with ma car when they serviced it n all but now it's all good
firs ttime took it to nissan but hell expensive now might just try C-red or hyperdrive=)
ma 2c worth for ya.
Gdluck
https://www.sau.com.au/forums/topic/211943-r34-problem/#findComment-3745940
Definitely something wrong there, I have an auto and it should only flash 'slip' when taking off hard under wet roads, or taking tight corners hard at from 1st -> 2nd under high revs.
Maybe your auto box is about to die. I wouldn't drive it till you find out what's wrong imo.
Edited by Magic
https://www.sau.com.au/forums/topic/211943-r34-problem/#findComment-3746858
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
