RB20 -red top engine with silver top turbo...
just wondering if anyone has done this mod, and wondering if it is worthwhile... ????
because i can get one real cheap.
My turbo is in perfect nic, it just looses 4psi by the time it hits 6,000rpm (maybe this is a wastegate prb?)
i was told that stock RB20 silver top turbos will hold their boost until about 6,000rpm....true????
Dyno indicates my silver top hits peak boost at about 4500rpm and drops nearly 2psi to redline. Tiny stock turbos run out of efficency quickly, no amount of boost control electronic or otherwise is going to help it.
Ive never heard of this mod before, always figured both turbos were the same but the intake systems are different between the 2 motors. Im sure an RB head will correct me :D
Red17
I don't have boost drop until around 12.5psi (152rwkw).
Anything over that and it starts to boost drop.
I fitted the EBC and it will hold boost at 15psi BUT it is a little wavy and you can definately tell the EBC is working hard to hold the boost.
Fitting the EBC picked my power up from 155rwkw to 164rwkw.
But yer go the RB25 turbo and don't bother with the RB20 turbo.
"Put an exhaust on it!! My car has had 3" the whole time i've had and never had the boost drop off. The R32 turbo is much better to drive as it spools up a lot sooner."
yea thats what i was wonderin... i do have a 3" mandrel zaust, but i still loose heaps of boost up top
Sorry guys my car has always had a R32 turbo on it, non Skyline non ball bearing at first and then when i changed engines a ball bearing one which spools up alot sooner (about 2000rpm sooner!). But both engines started to lose power about 6500 they still reading full boost.
Carlos
nice one 32-gts, i was told bout the later model turbos but i dont know how to identify them, and i didnt know what years they were made... Yea i was surprised at actually how small the compressor wheel was when i took the intake piping off to have a look...!! didnt measure it but looks hell of a lot smaller than a standard t25 off an sr20..
11psi with zorst and cooler?
Nah... somethings not right my car and others... usually rise to about 9-10 psi with zorst/cooler.
11psi... hrmm...
My old coupe hit around 8.5-9 psi with the zorst.
does a bigger cooler help increase boost?
wouldn't imagine that it would.
and joel... full boost meanss the point where you turbo hits the desired psi.
If you set a belled value to say 20psi for instance, then when you hit 20psi is classed at full boost.
Make sense?
Sorry guys, i'm wrong, i watched the boost guage today and it does drop a couple psi above about 5000-5500rpm. Time to make up a dump now.
Nismoid, its a pretty good cooler kit, the guy who makes them designed it on his stock R33 which gained 40HP at the wheels with just the cooler, standard exhaust as well. The R31 coolers are just shit, even a standard R32 cooler will probably make a difference on a R31.
Carlos
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
