Item:rb25det head
Age:90,000 klm
Condition:good
Price:500300
To Fit: (What car)what ever you want
Contact:pm thru here or 0438069499
Comments: head will have all lifters in it with cam covers and timing belt cover
Item: r33 turbo s2
Age: unknow
Condition:has a lil wistle being checked over no shaft play at all
Price:250200
To Fit: (What car) r33 r32 r34 r32 what ever you wnat it to
Item:oil relocation kit with b&m cooler and thermostat and goodyear hoses
Age:3,000 klms old
Condition:good just needs a clean
Price:300220
To Fit: (What car)r33 gtst or r32
Comments: comes to fit a r33 gtst with brackets and all
Item:mech 2 way diff in housing
Age:2 years old
Condition:good filled with royal purple oil
Price:600 ono or swap with cash of standard diff
Comments: locks up great for high powered car i dont need it anymore as i has stock motor ill swap someone with cash my way
Item:oil cooler not sure what brand
Age:new
Condition:still in box
Price:50sold pending payment
To Fit: (What car) any
Comments:brought it never used it
Item:series one ecu
Age:as old as a series one r33
Condition:good
Price:10050
i also have a set of brnad new pineapples to suit a r33 gtst
price 75 dollars 50
also have a set of r33 gtst s2 coils with loom
all im perfect working order no cracks
only 75,000 old
150 dollars 80
one complete r33 gtst s2 loom the whole thing with ecu in perfect condition
all plugs are there no cut wires all gromets aswell
not sure wat there worth
asking 300125
r33 gtst fule pump working no probs
price 50
Edited by teazn_r33
https://www.sau.com.au/forums/topic/212650-r33-parts-massive-price-drop/
  • Replies 45
PICS OF COOLER KIT?
as of friday ill have them up sorry
would u be keen on a direct swap for a rebuilt standard diff... i have just spent 800 on the build of it..
nah lookin to make a lil bit of cash
i msgd u on ur phone man.Just interested in ur plenum and pix would be good to.Thanx
msg replied
What style of thermostat does it take? and what temp is in it, is it adj? what condition was the engine in that it was fitted to, how many kms did it have good oil pressure, what type of oil was used etc?
Cheers,
Ryan
the engine it was fitted to was a brand new built rb25det not sure on the thermostate it takes oil used was royal purple pressure was fine when it was fitted brought this of a group buy off here
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
