Hi all,
Just wanted to know if anyone has done an install of the new just jap cooling pro stealth fmic kits onto their R34 GT-T?
Also,
1. Did you have to cut away any metal?
2. Does the air-con fan/compressor get in the way of the core? I know the horns need to be moved, but what of the aircon?
And yes, I've searched a lot for these answers but have only come up with info for an R33 and for generic kits.
Thanks in advance,
Suj
https://www.sau.com.au/forums/topic/212656-r34-fmic-installs/
dont buy the kit man its f*kn shit, gets in the way of a aftermarket bonnet, you have to get rid of your engine bay cover, yes there is cutting (under batt tray) and yes the fan gets in the way.
shit kit buy something else
but it is cheap.........and thats why i bought it -_____-" replacing soon thoughh =]
Edited by R34NRG
Actually this kit is the new stealth one they have just released...it uses the standard inlet and outlet of the stock SMIC. Its similar to the Blitz LM and ARC kits. No cutting under the battery tray or anything.
Relocation of the Aibag crash sensor may be required, it sits nicely about 10cm below it's current location, just drill a new mount hole for it. Horns can be relocated to the side of the bumper support and rewired in. Really would be good if it was a full 3" inlet and outlet as well.
LoL
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
