Hey guys. I just got my first skyline about a month ago and i'm loving it. I've been lurking here for ages trying to learn as much as i can and i've decided to start some mods on my R32.
I've already got a split dump with 3 inch exhaust and a pod filter and fmic with manual boost controller. I want to upgrade to a bosch 040 (or similar) fuel pump and also an rb25 turbo.
My question is about tuning? I've gotten a quote for $1300-1500 for a remap. Is this because you can't do live tuning on the stock ECU or something? It seems pretty expensive, and for that price i could nearly get an aftermarket ecu and have that tuned couldn't i?
Is nistune a better option?
I'm sure you are sick of hearing this noob question but i searched and couldn't find anything specific to prices and good tuners near the Penrith/Western Sydney area (i don't mind a drive to find a good place).
So as far as my engine management options are, what do you recommend?
https://www.sau.com.au/forums/topic/212744-need-advice-on-tune/
I was quoted 2 days work aswell. So it's probably a long and arduous task to remap an ECU. Hence the price.
Just been looking around... would i save myself some money if i bought a nistune and installed it myself, then took it to a tuner to get it programmed?
who quoted you $1300-$1500 for a remap?
Silverwater Auto Services (SAS)
Edited by Tree Fitty
I've been quoted $350 for a remap.
If you are in the market for it a power FC is a good option. But if you choose a remap ask around for prices!
You could also go piggyback, SAFCII/NEO for example.
For tuners in Western Sydney i recommend Unigroup or CRD.
it's not. it's an hour install at most and then a tune.
Link 3 Sydney workshops who can do the job are listed. All have a good rep. I'd be talking to all 3 before making a decision.
edit: SAS used to be your only option about 5 years ago. Not anymore. They still try to charge like they have a monopoly
Edited by BHDave
Thanks alot guys. I'd already spoken to unigroup but they don't do remaps unfortunately, only nistune.
I'll hit up the other two and hopefully be in business.
Cheers
Lol... So what were they gonna do with my car for 2 days?
Hi mate I just got a remap tune and the cam gears dialled in
by Dr Drift and the results are f@#king awesome and cost
no where near the $1300 -$1500 you were quoted.He is well
worth the drive down there or can do a mail order chip.He
would be 1 of the hand full of people that I would let touch
my car he is that good.I choice to go this path as it still
uses a lot of the features of the std computer and cheaper
than a PFC.If you live in the sydney area I can let you
have a drive if you like
I've heard nothing but rave reviews about people seeing Dr. Drift. But the 16 hours round trip kinda put it out of options. Interested in the possibility of a mail order chip. How would that work? Would it be accurate enough even tho he's never seen or touched my car?
The mods you are doing to your car are the exact same things that everyone else does.
Contact 2 users from these forums for their thoughts and prices.
TOSHI
CEF11E
Thanks man i'll hit them up.
For that price get a POWER FC its better in the long run you can retune whenever you like and most competent tuners can tune it easily within precise variables for your car...
DONT YOU DARE SPEND 1300-1500 on a remap THAT WOULD BE A BIG MISTAKE get the standalone it will prove its weight in gold.
Also if you cant find a GTST power Fc you can use a GTR power Fc from a R32orR33 as long as it is D-jetro so you can bypass the maf and run it from a map sensor.
I am using one on my GTS4...
ive basically got the same mods on my r32. Rb25 turbo not in. I bought the CEF11E remap. Havent got it installed yet, but seems to be the cheapest way to go at only $100. Ive also bought a safc2 for a finer tune once on the dyno if needed.
Thats the way im gonna go. I guess its about how much u want to spend really.
I have seen plenty of remaps with daughter boards.
Cheers
Gary
yeah, i know. Its the coilovers vs "coilovers" argument again.
But there are 2 distinct ways of achieving the same result with a stock ecu. replace the stock prom, or slap in a daughter board. I would not class a daughter board as a remap, it implies a different method.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
