  • Replies 114
busted car?
no tune...no dog box...no diff and no NOS.
i dont race for points i race for E.T's no 9 sec PB passes on current set-up...so fu(k it
id rather come out and race it when its ready, than spending time away from the family and money running it 1/2 arsed.
INTRODUCING GRUDGE CLASS FOR ROUND 3
Not interested in competing? Aren't sure about the rules? Don't want to be eliminated 1st round? Want to kick back and watch the racing after having a few runs? Just want to do a few laps like a Wednesday night Test & Tune?
If so, the Grudge Class at the Mackenzie's Motor Trimming Compak Attak, Round 3 of the Toyo Tires Sport Compact Group Drag Racing Series is for you.
"There seems to be a large number of people that race at Test & Tune events, but don't race at Competition events so we decided to combine them both and have a Grudge Class" comments Ray Box of the Sport Compact Group.
"We'd like to invite the regulator Test & Tune Sport Compact racers to come along and do a few laps at the Mackenzie's Motor Trimming Compak Attak and at the same time see what a Competition meet is all about. We get the Grudge Class out for as many laps as we can with the Competition Class" said Box.
So if you are 1st timer or a regulator Test & Tune racer why not get along on May 18th and support the Toyo Tires Sport Compact Drag Racing Series. All you need is a 4 cylinder, 6 cylinder OHC or rotary powered vehicle along with the normal safety equipment. If you've never been racing before download the Go Drag Racing page for everything you need to know about putting you and your vehicle safely down the ¼ mile.
Follow the link below to enter online. When you get to the Drag Racing Class option select the Grudge Class and away you go. If you have any questions feel free to drop us an email via [email protected] or give the Sport Compact Group Office a call on (07) 3200 1363. We look forward to seeing you at Mackenzie's Motor Trimming Compak Attak, Round 3 of the Toyo Tires Sport Compact Group Drag Racing Series
mmmmmmmmmm, yes the guy has trouble spelling,
but the point is people can have some fun without competing.
Our shop will have four cars going. Five if you get your act together....
What do regulators have to do with anything? WTF?
can anyone confirm that entry list is now full and that no on the day entrys will be taken?
Edited by BezerkR32
From: Sport Compact Group [mailto:[email protected]]
Sent: Tuesday, 13 May 2008 1:59 PM
To: - YOU ([email protected])
Subject: Mackenzie's Motor Trimming Compak Attak
Hi All,
We are only days away from the event. With that we are trying to finalise the race schedule so I need a confirmation from each of you that you'll be racing this Sunday. We have 170 competitors so it's going to be a tight schedule to finish before the track gets to cold down there. If you are not going to make the event please let me know so we can adjust the schedule.
We are planning to give everyone 3 qualifiers but as you know, breakages, oil downs, crashes etc will affect this.
Over the next couple of days we'll have the schedule finalised and you'll be emailed a copy along with it being posted on our website.
Attached is your competitor declaration form which must be filled in before you arrive and brought with you on Sunday but DO NOT sign it.
Pit allocations will be made before the event so if you wish to be pitted with some specific let me know by Wednesday night at the latest.
Best regards,
Ray Box
Sport Compact Group Pty Ltd
P.O.Box 1080
Browns Plains, QLD, 4118
Tel/Fax: (07) 3200 1363
Mob: 0411 756 000
Web: www.sportcompact.net.au
Email: [email protected]
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
