Originally posted by pushead
Awesome!. Finally got my SAU stickers. anyway here's what it looks like:
Hey nice!
I dont mean to put a downer on it but I have heard it is illegal to blockout the sign which has the Glass Manufacturer's Standards Number on it! [AS XXXX etc]...
you may want to check it out with Vic roads, or maybe not - up to you. Either way they are nice stickers.
I believe you can request them in white like we did for our www.skylinesaustralia.com stickers for MAS. Same place :D
guys you are missing my point, I did not say "it was illegal to put a sticker on your rear quarter window"
I said I have heard its illegal TO COVER UP THE GLASS STANDARDS sticker its about 2x2cm in size. These standards [including labelling] are part of ADR[egulation] and if your car can be shown to NOT comply with ADR's guess what? Defect!
read my post again if you must...its just a warning. Someone told me about it at MAS when I was applying my 3/4 window stickers :P
obviously i didnt cover the labels on mine.
and I dont think you can do this either "surely they let us tint rear quarter and back window as dark as we like"
If you read through the regs on vic roads website you will find that a normal private use vehicle must have a minimum 35% light transmission on all windows - with the exception of the front w/screen which is obviously a different case...
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
