Need For Speed Pro Street Xbox 360
Guest trikdoutvl
hi all
just wondering in drag mode wat kinda 1/4 times are u getting i found the best car in the game was the zonda i got it to run a 6.85 with everything moded and soft suspension and full boost
also i could only get the gtr r35 to run a 8.9 pretty disapointing considering my old ford gto could run a 7 second pass.... howz every else going wat ur fastest 1/4 times n wat car did u use...
also how frikin hard is the drift mode i find it almost impossible to change directions when sliding, wats some keys to awsome drifting do u tweak the suspension settings gear ratios???
https://www.sau.com.au/forums/topic/213467-need-for-speed-pro-street-xbox-360/
  • 3 weeks later...
Hey guys, when driftin I use maximum positive castor on front, set 2 deg camber on rear/ 2.5 deg on front, lower car, stiffen front & rear swaybars up to 1point off max, suspension to the same with 1 less point on damper set ignition timing +2steps positve, adjust boost to come on -1 step before mid and maximum adjust. on top rev, use the AE86 with 15% wider rubber & rims, max score on short track 7650pts, need4speed carbon-2,150,000pts on kings rd circuit in bombed RX-7(kenji's car)this is on ps2 tho
Worst game ever!
I got so frustrated when i first played this game.The best version is Hot Persuit IMO.
W R O N G
Need for Speed 1 for the win!!! Car physics beyond its time!!
Same thing with Gran Turismo series, none of the game physics compare to those of GT1!
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
