Hello,
Dont want to sound ignorant, but what size are the size of the rotors on the M35 Stagea, looking to upgrade the brakes.
Are they the same as the V35 Skylines.
If you know can you please post up all specs.
Jules
Hi Jules
I do not know the size of the rotor but they are the same as the V35. The part numbers are the same. The brake pads are also the same as the V35/G35. (confirmed this with Ben).
I am looking at getting some Hawk brake pads from the US for front and rear. Just waiting to confirm the cost of rear pads.
Cheers
Andy
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3772848
Hi Jules
Cheers
Andy
Hello,
Ok that should make it easier then, I was looking at these from A & B Motor sports, who are conveniently located in Brookvale.
http://www.aandbmotorsports.com/brake.html
I like the looks of the 6 & 8 Pot Brakes. The brakes on the M35 Stagea are less than desirable, I reckon some 8 pots would help a bit.....LOL
Jules
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3773992
Hello,
Jules
I noticed they only listed the G35 from 2006 on. Lets hope it still works.
We will have to meet up some time. I will be working in Cromer from May.
Cheers
Andy
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3774056
Cheers
Andy
Hello,
I just spoke to them and he told me he noticed a huge difference with his R33 Skyline with their brakes. He suggested 8 Pots for the front and 6's for the rear. They are designed to run off the stock OEM master cylinder. Prices were
$2,200.00 for front 8 Pots - 330mm rotors
$2,300.00 for rear 6 pots - 330mm rotors
Excludes fitting, they could fit them for about $200'ish if purchased directly through them.
Jules
Edited by Paramour
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3774873
Below is the part numbers on the actual pad for the M35 Stagea VQ25DET and the various non Brembo brakes on the V35 Skyline, their is a bit of a difference on sum.
M35 Stagea
Part no. on actual front pads: NISSAN HITACHI HP63H FF
Part no. on actual rear pads: NISSAN AK AP66 FF
Part no. on actual rear pads: NISSAN AK AP55 FF
V35 Skyline
Part no. on actual front pads: HITACHI HP66H GG
Part no. on actual front pads: HITACHI HP63H FF
Part no. on actual front pads: TEXTAR T4146 FF 41 (Replacement Part No. 41060-AM892)
Part no. on actual rear pads: AK-FF AP63H
Part no. on actual rear pads: AK-FF AP55
Part no. on actual rear pads: AK-FF AP61H (Replacement Part No. 44060-AM485)
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3776643
  • 2 months later...
Does any one know could the brembos from a v35gt be fitted to an NM35 stagea
Wish I could help you. Maybe ring Ben or Tony at Northshore Prestige in Sydney. Cannot see why they wouldn't though.
BTW. If thats your car in your profile you need to stick more pic's up. Look's F...king awsome.
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3927061
OK. Today I thought I would go through our old R32 GTR bit's to see what fit's and what doesn't. So here's what I came up with. Found an old set of front R32 GTR 4 Spot calipers measured them up and they fit. Small issue with some spacers to be made up(cost about $15 for the spacers) but everything else will fit perfectly. So if you want a cheap upgrade get you hands on a set of front R32 GTR calipers and you done.
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3944323
Mmmmmmmmmm....Very interesting......
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3945513
The front Brembos off 350Z, V35 Skylines will fit without any mods at all. I trial fitted them when I took off my Brembos from the Zed.
The rears im not sure 100% but my guess is that it's possible.
For a good used complete set of Brembos, you're looking at about $2500-2800 including calipers, rotors and pads. Im considering upgrading the brakes next.
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3969160
Fitted up the R32 GTR callipers tonight. Pretty easy job....you will however need to cut and linnish the bolt going into the caliper from the brake line.
The other thing you will need is rotor's that have a minimum thickness of 30mm(M35's are 24mm).....hopefully sorting some R32 GTR rotors tomorrow.
P.S. I will post up step by step once I have everything 100% finished....looking like a very cheap option still.
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3982592
R32 GTR Brake setup done.
Parts needed:
*R32 Rotors
*Pads
*1 LT of brake fluid
*4 Spaced washers to go around the outside of the bolts going through the suspension arm and bolting to the caliper
Parts needed to be modified
* Remove or cut off the dust guard on the inside of the rotor.(if you have a nibbler this is a fairly quick job to cut off)
* Take about 1mm off the brake line bolt going into the caliper...or buy a new shorter one.
All up cost for everything was:
*$280 for the calipers to get rebuilt(or whatever your cost is for new ones)
*$80 for the Pad's
*$300 for brand new rotors
*$20 for Brake fluid
*$45 for Spacer washers to be made
*About 2 hours worth of your time
P.S. The only thing I have not yet tested is that the standard wheel and space saver fits...will let you know soon.
Edited by Jetwreck
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3988323
I guess the important question is, how does it feel and perform......compared to stock...
If I was to compare them with the new Nismo pads I had just put in the standard calipers its a definite improvement....lots more feel through the brake peddle.....mind you I have not had a good stand on them yet.
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3989072
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
