Do you get boost drop with your R34?
36 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
OK I've been looking through lots of threads comparing notes on all of the R34's that have started on their mod journey...almost everyone of them suffers from a marked boost drop in the second half of the rev range, more than you would typically expect from a similar modded R33.
One thing that has come up with my playing on my car is the TCS butterfly is pretty limp and I did see some gains from removing it.
Anyone out there actually got a dyno chart of an R34 with stable boost?
I must admit r34's cannot hold as much boost as the r33's do. and i speak from having both cars. i have both dynoed, and r33 seems to hold boost much stably unlike r34's which always decreases nearby redline even with a electronic boost controller. nonetheless, it still gives out alot of power.
Hi
Here is the dyno reads from my 34. its running a apexi turbo and it doesn't seem to lose much boost through out the rev range. hope this kinda help in what you are after.
Adam
Hey mate what engine management are you running just out of interest? We think we've found a look-up point in the factory ECU which down-regulates timing based on a few things, just means chipped ECU's are a pain to use unless you eliminate it.
What plug and play ECU options are available for the R34 Auto ?
I just picked up a 4 door and want to do some mods :-)
You can put a bikirom in, it's a daughter board that currently allows full adjustment of fuel and timing, this weekend we're emulating the factory ECU and unlocking every bit of it we can find in the tables, so basically full controll over everything and anything that it does (hoepfully find this crazy retarding map that's hiding in there and stopping my 250rwkw fun)
  • 4 months later...
digging this up Dan :P
just had my car remapped
mods
full 3" turbo back exhaust (BATMBL stainless split front/dump pipe, hi-flo cat (not the biggest one), HKS Super dragger catback)
Turbotech boost controller set at 12psi
FMIC (return flow one, from Just Jap)
Splitfire coilpacks (not really a mod i guess)
Blitz hi-flow panel filter
that's it i think, for the engine anyway :banana:
Boost drops at 4250rpm, to a low of 8.6psi i believe. Despite this, car made 180rwkw, and 190rwkw with the airbox cover removed :P, so if i can sort out the boost drop issues, tuner reckons the standard 200rwkw+ with these mods should be easy. Just want something in the 200's damn it!! :P
will put up dyno sheets
so i have lost around 3.5-4psi, with a the bc "set" at 12psi
I had my car tuned with a power fc and a profec b spec boost controller. I dont get a lot of boost drop (no more than 1-2 psi) tuned at 12psi.
I have only done the exhaust (3" turbo back), the intercooler is still standard along with everything else. Made 180rwkw.
I originally thought it was tuned to 10psi but later realised it was dropping to around 10 from 12 lol.
Im happy tho as it is well into its peak power by just before 5k and holds pretty well until redline.
  • 2 months later...
a bit of a dig but car is going in for a tune on thursday with new fuel pump so will post up dyno then.
atm car is running 220rwkw with the following mods
highflow turbo (16psi)
turbo back exhaust 3.5" all the way
FMIC
Z32 AFM
PFC
480cc injectors
highflow fuel rail
HKS cam gear
and a dieing fuel pump.
before injectors went in car was running 18psi and fuel pump was reasonably ok and that made 241rwkw so atm 220 is for a temp safe tune. once fuel pump is in looking at a safe daily tune of 260rwkw.
have a dyno graph here of the car when running 241rwkw and no boost drop at all. will post pic once silly scanner is working.
but ye will also post pic once car is dynoed on thursday
I've noticed the drop in boost your talking about. Mine seems to happen around 4500 to 5000rpm? i think. I will go for a squirt today. Im having a tomei fuel pump and turbosmart fuel reg installed tuesday and hopefully nistune done wednesday or thursday so I will post up dyno graphs. May be helpfully to have a less modded skyline with graphs to see if theres anything else that may be the cause of this.
    • PayPal is a safe, online payment system that enables businesses and individuals to safely send and receive money, making it an indispensable tool in both personal and professional contexts. However, many users wonder how to send money on PayPal? Don't be alarmed if PayPal is new to you - all the steps can be found by visiting merchant sites with links marked "Pay or send money". Once clicked, select payment method, amount, and add message or note for recipient(s). Upon successful transaction completion you will receive an email containing details of transaction. Let’s start by understanding how PayPal works, how money transfers from banks to PayPal and using various payment methods. Moreover, to transfer money between PayPal and bank, head to the Wallet section and click "Add Account", selecting either "Transfer within seconds with debit" or "Transfer between 3-5 days with bank", and following any instructions shown on screen until completed successfully.   How to Send Money Over PayPal: The Basics Before sending money through PayPal, first create an account. Here is how to set-up a PayPal account: ·         Click “Sign Up” on either the PayPal website or app to enter your basic information such as email address or name into their system. ·         Link your bank account, debit card or credit card directly with PayPal so you can fund transactions directly using these accounts. ·         Verifying your PayPal account will enable you to send and receive more funds. Typically, PayPal requires that you verify your credit card or bank account by making small deposits into it. ·         Once your PayPal account has been established, you can send money through it.   How Do I Send Money to Someone on PayPal? After creating a PayPal account, you can easily send money through it. Here is how to send money to someone on PayPal: ·         First of all log into your PayPal account ·         Once on your dashboard, click on "Send & Request Tab." ·         After this enter the recipient's email or mobile phone number. ·         Enter the amount you wish to send to someone. ·         At last, recheck all the details and click "Send Payment" to complete your transaction if everything looks in order.   How Can I Send Money PayPal for Goods and Services? PayPal provides a safe method for individuals and businesses alike to transfer funds online, both personally and commercially. When paying for goods or services there are additional protections in place both for buyers and sellers. PayPal Buyer Protection offers you peace of mind when paying for products or services with PayPal. In the unlikely event that there is an issue with a transaction, if there are any discrepancies you may dispute it and be eligible for a possible refund. You need to follow the same steps to send money, but select Paying for Services or Goods when prompted. In fact, this extra layer of protection will keep your account safe from fraudulent attacks.   How to Transfer Money to PayPal from Bank? Here is how to transfer money from PayPal from bank: ·         Log into PayPal using either its app or website. ·         Click "Add Funds" in the Wallet section, and add money directly from your bank to your PayPal account. ·         If you have linked your bank account with PayPal, select it under Funding options to select it as your funding option. ·         Enter the amount you would like to transfer to PayPal from your bank balance. ·         Click Add Funds. It typically takes several days for funds to arrive on your PayPal account.   FAQ How can I send money PayPal? Log into your PayPal account, select "Send and Request," enter in your recipient's phone number or email address, select the amount due, payment method of choice and click on "Send Now" - quickly and safely sending money via PayPal is now an efficient method of money transfers!   How do I transfer money to PayPal from a bank? Log into PayPal and select "Add Funds" to transfer money from your bank to PayPal. Select your account number, input an amount, and confirm it. Though the transfer may take up to several days for completion.   How do you send money to someone on PayPal? Simply log into your PayPal account, select "Send and Request", enter the recipient's phone number or email address, select the amount to send, and click "Send Now".   How can I receive payment through PayPal? Senders can easily accept payments with PayPal by providing your PayPal email address and being notified via email when a payment has been completed. When funds appear in your PayPal account, they will appear instantly!
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
